Delay in toilet tank re-fill
Discussion in 'Toilet Forum discussions' started by mkl2209, Mar 19, 2006.
  1. mkl2209
    mkl2209 New Member
    Mar 19, 2006
    After flushing, my toilet tank won't start to re-fill for a minute or two (sometimes longer), then it will smoothly and completely re-fill. I replaced the old ball cock assembly with a Korky fill valve, but the problem continues. All other toilets in the house work fine. Suggestions, please? Thank you!
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Is the supply tube a flex connector? I have seen them kink inside at a sharp turn and take a while for the water pressure to reopen the kink.
  4. mkl2209
    mkl2209 New Member
    Mar 19, 2006
    No, I have the rigid metal supply line.
  5. Since replacing the fill valve didn't fix it, it sounds like either an obstruction in the supply line or an issue with the supply valve itself. I would replace the supply line first, and make sure no sediment, etc., from the water supply has moved up into the fill valve.
  6. Cass
    Cass Plumber
    Nov 12, 2005
    Try replacing the shutoff valve and supply line. Use a braded stainless supply line.
Similar Threads: Delay toilet
Toilet Forum discussions Delay in Toilet Water Refill, After Flush Nov 24, 2007
Toilet Forum discussions Bad float? Delay between flush and beginning of fill Jul 8, 2016
Toilet Forum discussions Delayed flush lever Aug 26, 2013
Toilet Forum discussions toto drake delay filling Oct 24, 2008
Toilet Forum discussions Drake: Delayed Fill Feb 25, 2006
