deep well pump won't reach shutoff pressure
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Lynnfish, Aug 12, 2010.
  1. Lynnfish
    Lynnfish New Member
    Aug 7, 2009
    1 hp Starite deep well, with packer ejector and foot valve. Filled pipe and pump thru pressure gage. Holds prime. Started with the pressure Regulator completely closed. Pressures to 40lbs. right away but will not reach shutoff pressure of 50lbs. Pressure drops to zero immideiately when power is cut. Please let me know if I can provide any more info. Thanks so much for your time and advice!
    Lynn
  2. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    It sounds like the nozzle in the injector is partially plugged causing the low pressure. Not holding pressure usually means the packer leathers are leaking or a leak in the well casing.
  4. Lynnfish
    Lynnfish New Member
    Aug 7, 2009
    we had the pump rebuilt and they left out a gasket , we carefully cut a gasket and re-assembled the pump could there be an enternal leak in the pump . we have a shut off valve one foot from pressure control valve , so the system should pump up right away , one would think. we had the pipe out of the well. we installed a new foot valve , new leathers, new gasket and plunger internal to the ejector, inspected the venturi and there was no blockage. i am at a loss for words damn it
Similar Threads: deep pump
Pumps and Tanks Well Forum & Blog. Water is life. Flat or twisted cable for deep well pump Today at 8:25 AM
Pumps and Tanks Well Forum & Blog. Water is life. Sta rite 1hp vertical deep well pumping but not building pressure. Jan 9, 2017
Pumps and Tanks Well Forum & Blog. Water is life. How to repair Goulds deep-well pump Sep 24, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Should I Winterize my deep well pump? Aug 20, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Best deep pump Jul 27, 2016
