Danze 5020-57, Can someone ID this valve and help me fix it?
Discussion in 'Shower & Bathtub Forum & Blog' started by jed1154, Aug 22, 2010.
  1. jed1154
    jed1154 Member
    Feb 11, 2008
    Texas
    Here is the valve:
    [​IMG]
    The diverter portion on the bottom, as you can see from the color, is leaking. It leaks when the hose is turned on and it leaks into the wall, which shows up in the toilet area on the other side.
    What valve is this and what part do I need to replace? It looks like it leaks where it threads into the valve and also around the part that 'turns'.
    Can someone help me out?
  2. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    Looks like a Toto TSPVR, have to do some research for parts.
  4. jed1154
    jed1154 Member
    Feb 11, 2008
    Texas
    OK...thanks a ton. I was not aware my shower had any temperature limiter on it??
    One more thing. I found a 'manual' for a Danze 5020-57 that has drawings that look very similar to mine.
    Is there any chance it could be a Danze?
  5. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    Dan
    Danze is made by Delta. I believe their balancing spool is located in the shower cartride. The picture of you're valve shows the balancing spool in the valve body. It is the hex shaped bolt head located next to the screwdriver stop in the picture. Where did you "find" the manual? How many baths do you have in you're house. Danze is the high end Delta line of fixtures. Can you post a picture of the handle and trims?
  6. jimbo
    jimbo Plumber
    Au contraire...Danze is made by Globe Union. http://www.globeunion.com/page.php?key=marketing
    I was going to say that the valve and the trim cap/sleeve resembled Glacier Bay, also made by Globe Union. Could be Danze. Does not seem to resemble that toto diagram
  7. jed1154
    jed1154 Member
    Feb 11, 2008
    Texas
    I 'found' the manual in my attic with all sorts of extra parts and such. See, my home was built by the owner/builder, and all parts were purchased beforehand so they would be available as they completed the home. As such, I have fixtures, sinks, plumbing, electrical...all sorts of stuff in boxes and this happened to be an open box with a manual in it. I have three full baths, but only two are completed...the master and the guest bath.
    Thats where I found the manual. Is there a way to tell for sure? I need to get it repaired as its the master bath.
  8. jimbo
    jimbo Plumber
    So this is a secret manual with no name or number on it????
  9. jed1154
    jed1154 Member
    Feb 11, 2008
    Texas
    No secret, its listed in my second post. A Danze 5020-57...but I am not SURE its for the one in my master bath...thats my point. It is likely a manual for the one in the master OR guest, but I am not sure which. Thats why i asked.
    EDIT: I sent the picture to TOTO and Danze....I just got an email that Globe Union is shipping me the diverter assembly and o-rings....so, I guess that answers my question. It must be a Danze.
    Am I to understand (as per reading this site) that Danze is High end cost and low end quality?
    The unit is probably about 10 years old. What sucks is that I don't know its leaking until it comes through the bathroom tile grout on the other side of the wall.
  10. jed1154
    jed1154 Member
    Feb 11, 2008
    Texas
    Also....both Toto AND Danze have replied to my emails and pictures and claimed it to be their product.
    Wierd. Toto wanted to charge me for the diverter, Danze just shipped me a new part. I guess Ill wait for the danze part and see if thats it or not.
  11. jadnashua
    If you showed the trim, that may help as well. From the pieces I've seen, Toto usually has their name on the trim somewhere, which may also may shed light.
  12. jed1154
    jed1154 Member
    Feb 11, 2008
    Texas
    I should have photo'ed the trim, but I assure you, there are no markings for brand anywhere on it. The only markings are 'tub/shower' and 'hot/cold'....
  13. jed1154
    jed1154 Member
    Feb 11, 2008
    Texas
    Since someone asked me about this valve and I was selfish enough to not follow this post up, here is what I know about the valve:
    Mine is a Danze 5020-57 valve. TOTO apparently has a very similar valve. Toto wrote back and identified it as their valve. However, Danze sent me a free diverter valve and it went in without any issue, plus I have Danze literature around here.
    Here is what they sent for my leaking diverter:
    Part Number Qty Part Name
    A072002 2.0 O-RING(?16*?2),NBR
    A101000N 2.0 SEAT,?11.4*?5*6.3L?11.6,EPDM/CY-E38012-A
    A005000 2.0 SPRING,D9.8*d1*D8*7H,SUS304
    A607223 1.0 DIVERTER ASSEMBLY
    Tech Services
    GlobeUnion North America
    TEL: 888-648-6466
    http://www.danze.com/single-handle-tub-and-shower-faucet-trim-kit-with-8-showerhead/d502057t/
Similar Threads: Danze 5020-57
Shower & Bathtub Forum & Blog Danze shower mixing valve/diverter question. Nov 24, 2013
Shower & Bathtub Forum & Blog Need help to identify Danze shower diverter brand and how to fix it Nov 23, 2013
Shower & Bathtub Forum & Blog What shower valves are these? Grohe & Danze Aug 4, 2013
Shower & Bathtub Forum & Blog Shower diverter broken! Need help identifying model. Danze "Parma" Jul 30, 2013
Shower & Bathtub Forum & Blog Mystery shower valve? Danze, Global Union, Pegasus Dec 13, 2012
