Cutting swanstone
shamrock_94
Michigan
Does anyone have an experience installing shower walls with this material? In order to install the walls, I need to cut a hole for the shower valve. Would a RotoZip carbide bit be acceptable to use? I plan on using the RotoZip with a circle guide to cut my hole.
Randyj
Alabama
Looks like no one else has replied... call Lowe's and let us know what you find out.
The Marble Guy
Cultured Marble installer /remodeler
Texas Panhandle
You can cut it with a fine tooth or metal hold saw or jigsaw.(14tpi) I use a 4-1/2 inch hole saw on cultured marble for the valve. It works much in the same way. I have installed both and enjoyed working with the solid surface products.
