Cutting swanstone
Discussion in 'Shower & Bathtub Forum & Blog' started by shamrock_94, Jan 6, 2007.
  1. shamrock_94
    shamrock_94 New Member
    Nov 21, 2006
    Michigan
    Does anyone have an experience installing shower walls with this material? In order to install the walls, I need to cut a hole for the shower valve. Would a RotoZip carbide bit be acceptable to use? I plan on using the RotoZip with a circle guide to cut my hole.
  2. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
  4. Randyj
    Nov 25, 2006
    Alabama
    Looks like no one else has replied... call Lowe's and let us know what you find out.
  5. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    yes it'll work
    and you can get confirmation from Swanstone or anyone.
    david
  6. The Marble Guy
    The Marble Guy Cultured Marble installer /remodeler
    Aug 27, 2006
    Texas Panhandle
    You can cut it with a fine tooth or metal hold saw or jigsaw.(14tpi) I use a 4-1/2 inch hole saw on cultured marble for the valve. It works much in the same way. I have installed both and enjoyed working with the solid surface products.
Similar Threads: Cutting swanstone
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Feb 14, 2017
Shower & Bathtub Forum & Blog Cutting a cultured marble sink bowl out? Dec 31, 2014
Shower & Bathtub Forum & Blog Is this diamond cutting blade installed correctly? yes or no Dec 5, 2014
Shower & Bathtub Forum & Blog Cutting flange on alcove tub? Anyone done this before? Feb 13, 2014
Shower & Bathtub Forum & Blog Is methane dangerous when cutting cast iron? Jan 12, 2009
