Cutting And Then Extending Well Casing
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Regis Tration, Jul 11, 2010.
  1. Regis Tration
    Regis Tration New Member
    Jul 11, 2010
    Massachusetts
    I have a well in a very remote location close to the ocean, where it is exposed to salt air. The portion of the well casing that is above the soil is severely corroded.
    I would like to replace the corroded casing.
    I had in mind to dig out the soil surrounding the casing a few inches deep, cut away or break away the portion of the casing that is corroded, push a sleeve down over the part that is not corroded, and then insert a new piece of casing into the other end of the sleeve.
    It is very unlikely that I could get a welder to come to the well, so I am looking for a solution that does not involve welding.
    Can anyone recommend a good method and products please?
  2. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    It's not approved but you could dig down a bit and cut it off and then extend it using a Fernco coupling and then go to PVC which will not corrode.
  4. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    Fernco couplings are not an approved repair on any well anywhere!
    Your DIY remedy sounded best. Cut the casing off at a point where the casing is good. Then obtain a belled end of PVC the size of your steel casing, see that it will fit tight over the steel casing and if it will apply plenty of PVC Cement and push it over the cut off casing. NOTE: if the PVC is a little to small you can heat it over an car exaust or place the end in hot water until it's soft, then you can drive it over the casing, then let it cool befor removing it and applying PVC Cement. This is an approved repair in most states. . . however keep in mind that most states require this repair to be done by a licensed well driller. From here on you're on your own.
    Good Luck
  5. nhmaster3015
    Jul 30, 2008
    Teacher
    The granite state
    I'll back Porky.
  6. Regis Tration
    Jul 11, 2010
    Massachusetts
    Thank you both.
  7. ballvalve
    Dec 28, 2009
    northfork, california
    BP is doing something like that right now a little bit deeper underwater.
  8. Stonecutter
    Stonecutter Natural Stone
    Nov 5, 2008
    Maryland
    Pretty witty!
  9. hj
    Cut it off, then either thread the end of the pipe and couple on to it, or use a water line compression coupling, such as Dresser to extend it.
Similar Threads: Cutting Extending
Pumps and Tanks Well Forum & Blog. Water is life. well keeps cutting on and off May 29, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Extending a well casing Nov 22, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Extending an Existing Well Aug 8, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Extending The Well Casing Mar 2, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Extending Well casing Apr 14, 2008
