Culligan super S re-bed - new head
Discussion in 'Water Softener Forum, problems, installation and r' started by ternzer, Dec 31, 2013.
  1. ternzer
    ternzer New Member
    Mar 1, 2013
    3 rock from the sun
    Hi,
    hoping one of you gurus can help me out with my culligan super S. This 10 yr old unit came with the house and has been by passed for the last year while i decided what to do. In the meantime i have temporarily bumped up my softener to remove the extra iron. (i only have about 3 mg/l and a trace of H2S) Well after reading about others here re-bedding their super S i decided to give it a shot. I ordered 30 lbs of garnet and 1.5 cf of Centuar carbon which will be here by the weekend.
    The other day I took the head off and realized it was clogged with rusty goo. after a day of soaking in Iron out i was able to get the whole thing dissembled and cleaned. Now that it is apart i realized the seals were about shot. I have searched high and low and getting the seal pack kit for this unit is about impossible. I hate the local culligan crooks and refuse to buy from them and there is none on e*b*y at the moment.
    So, my questions.
    So rather than pay $100 for a kit I was thinking if I replace this head with a normal unit like clack or Fleck what would be a good replacement? My compressor still works fine. is there a head i could still use it with? Would the new head still use bleach to backwash the system? anything else i should consider?
    thanks for the help.
    Ternzer
  2. Gary Slusser
    Retired
    Their super S should have manganese dioxide (Pyrolox) in it or something similar, not any type of carbon. You have their version of an air pump system. Their backwash flow control (rate) will be too high for carbon and you'll backwash it up into the valve and out of the tank to drain.
    Also, their tank may not allow swapping control valves. How does your valve mate with the tank.... screw into it or have dovetail fittings? And if it screws into the tank, are the threads industry standard 2.5" dia x 8 threads per inch?
  4. ternzer
    ternzer New Member
    Mar 1, 2013
    3 rock from the sun
  5. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    Centaur is a bit spendy, but here are some other carbons that are out there, acid wash would be good mix with coconut shell would stand up to the type of use that you would be putting it to.
    The culligan tank threads are often square to the fleck or clack pipe like threading and the two do not cross over.
  6. ternzer
    ternzer New Member
    Mar 1, 2013
    3 rock from the sun
    Ok, it makes sense that they would use different threads. I guess ill just rebuild the culligan. Aquasorb looks like it has a similar catalytic carbon for about 1/3 less. Ill probably go with that and a garnet under bed rather than sand that culligan uses. thanks for the help
  7. Akpsdvan
    Dec 29, 2009
    Alaska
    Drop a note if there are some culligan parts that you are in need of.
  8. billy0510
    billy0510 New Member
    Jan 14, 2014
    Marseilles, Illinois
    anyone have any diagrams showing the bedding of this super S filter??? or anywhere i can get a diagram?
  9. Akpsdvan
    Dec 29, 2009
    Alaska
    Never really seen one.
    Head is removed and media is dumped out into buckets and tank rinsed out and then tube put back in with either duck tape over the open end or some other plug and then gravel and then media and then the valve back on top..
    Some like to fill the media tank with water before and letting set for an hour or so and then putting the valve back on top of the tank, makes it easier with no air to deal with when putting the system through a cleaning cycle.
Similar Threads: Culligan super
Water Softener Forum, problems, installation and r Replacing Culligan Super S Jul 12, 2016
Water Softener Forum, problems, installation and r Culligan Super S Won't Pull Bleach Jul 7, 2016
Water Softener Forum, problems, installation and r Culligan Super S Apr 9, 2016
Water Softener Forum, problems, installation and r Culligan Super S - air in water lines Aug 18, 2015
Water Softener Forum, problems, installation and r A couple of culligan super s questions Sep 22, 2014
