Culligan softener problem
Discussion in 'Water Softener Forum, problems, installation and r' started by TLplumbGuy, Sep 1, 2009.
  1. TLplumbGuy
    TLplumbGuy New Member
    Sep 1, 2009
    Canada
    Hi Folks,
    I hope someone here can help me out!
    I have a Culligan Medalist Series automatic conditioner
    (models 2000)
    Manual:
    Cat. No. 01882292
    Rev. B 5/11/01
    DCO #2527
    The machine has been working fine for around 8 years or so.
    Every once in a while because of power failure or such I need to call Culligan for help on re-programming the machine.
    Over the past few years the regeneration time has been slipping and slipping.
    It finally got to a time that was waking me up in the morning.
    It happened a couple of weeks ago and I went down and tried to stop the regeneration by unplugging the power.
    It kept regenerating, so I plugged it back in and went back up to bed.
    When it happened again yesterday, once again I unplugged the machine, but it kept regenerating. This time I unplugged a couple of plugs that go into the circuit board (a big pink one and a smaller white one), thinking that this would stop the regeneration. It didn't.
    I couldn't push in the Red water tab. I went back up to bed.
    Today I called Culligan to help me re-set/reprogram the machine.
    When a tech guy learned that my panel was showing an E2 error message he said I'd need to have a tech guy come over to my house to fix it!
    Is there some way to reset the machine?
    It was working fine before I unplugged the power and the other two plugs.
    Thanks in advance!
    Mark
  2. Gary Slusser
    Retired
    Yeah unplugging a control valve when a softener etc. is using water only prevents it from doing anything but using more water until it runs out of water, highly unlikely or, you shut the water off... and you can cause problems.
  4. TLplumbGuy
    Sep 1, 2009
    Canada
    Yup, that's the model I have.
    My manual doesn't show the error codes though.
    It looks like my motor's stuck.
    They quoted $100+ just to have a tech guy come over.
    Do you think they can 'unstick' the motor or am I in for a large repair bill?
    TIA
  5. Gary Slusser
    Retired
    It is what it is and you can't get parts anywhere but Culligan, so your choices are to have them come out to fix it, bypass it and use raw water or, buy a new softener.
  6. TLplumbGuy
    Sep 1, 2009
    Canada
    I tried choice #4 Gary.
    Yesterday afternoon, I used a wrench to bang in the Red hot water tab. That stopped the water from flowing.
    I also unplugged the power from the unit, and this time the display went blank for the first time!
    I was hoping that if I left it for a day that it might recover on its own.
    Today, I went downstairs and banged the Blue cold water tab in, so the Red tab came out again.
    The water started flowing again, right away.
    Then I plugged in the unit and *BINGO*, it started blinking the time!
    And a couple seconds later the water turned off!
    I think I have a good chance of getting her to work now.
    But I still need guidance in re-programming her.
  7. Gary Slusser
    Retired
    Very good.
    Without knowing what data it asks you for, and how much resin you have, and the hardness and iron you have, I can't help you program it.
Similar Threads: Culligan softener
Water Softener Forum, problems, installation and r Culligan Softener settings question - water too hard after power outage Mar 8, 2016
Water Softener Forum, problems, installation and r Culligan Softener always running Sep 10, 2014
Water Softener Forum, problems, installation and r Please help: Culligan water softener Jul 10, 2014
Water Softener Forum, problems, installation and r Installing used Culligan water softener + Potassium tank Apr 21, 2014
Water Softener Forum, problems, installation and r Culligan Gold series softener keeps regenerating Dec 13, 2013
