Mookie3333
Guys,
Please see the attached picture for my next question... I had to frame a third wall for my alcove tub. I have the vikrell tub in and set on a mortar bed, drain connected, no leaks, and I built this 2x3 "floating wall" which is only attached to the floor and the wall on one side. This wall will contain supply lines and the shower body.
My question: How can I stiffen this wall, to allow the least amount of movement? I was thinking about some type of steel L's, or another type of fastener to fasten the sole plate to the plywood subfloor. I also believe when I hang sheetrock, this will give it more strength as well. Any other suggestions? The wall is 7 feet high, and will be tiled fully on one side, and half way on the other side.
FYI: I used this exact same setup on the top floor apartment (same layout and everything) and its been fine up til now. The wall is stiff as ever, but I hired someone to do that work, so I'm not too sure how he did it. He did use cement board though, not kerdi on drywall like I'm planning to use.
