Mookie3333
Hello! I am remodeling a bathroom in my NYC row house, which was built in 1910 (!) It still has the original bathroom in there, up until this weekend when I ripped everything out. I noticed a sink in the floor, and after removing asbestos tile that covered the original hex tile, saw a long crack in the hex tile/mud bed. Now my job just multiplied! I guess today I'll be ripping out the concrete/mud bed, and all the hex tile down to the joists.
I've done a TON of work in this house in the past 2 years, and this is one of the last remaining projects. My questions to you guys:
#1. The joists are 2x8 (really 2"x8", not 1.5") 16 O.C. What type of subfloor do I need? 3/4" plywood?
#2. My lead closet bend is in reasonably good condition, which is a good thing because there are tons of pipes getting in the way around the area where lead meets cast iron at the stack. I really dont think i'd be able to get to it to remove all the lead and use a donut/pvc back to the flange. Can I somehow undo the flare on the lead, and slide off the existing flange? Then after putting down the new subfloor, screw down a new flange and re-flare the lead pipe?
EDIT: ok, I really won't know what I have to do with #2 until I get a good look at the flange. I was assuming it was flared on, but it could be lead-welded on. I'll update with pics later, but probably going to try and finisht the rest of the demo first.
I've attached a few pictures of the existing mud bed, or what is left of it. I plan on replacing all the lead drains/vents with pvc also...
