Can I use a “2 In. PVC DWV MIP Adapter Hub x MIPT†to connect to a cast iron stack? What type of thread sealant should I use?
The waste tube from the tub is 1 ½ is it in my best benefit to run a 2†pvc from the cast iron stack including a 2†p-trap and then tying in the 1 ½ waste tube? In other words where should I make the transition from 2†to 1 ½�
Should I add a “PVC DWV Elbow 22-1/2 Degree (1/16 Bend) HubxHub†with a “PVC DWV Cleanout Plug MIPT “after the p-trap and before the cast iron stack or that’s over kill and additional area to leak? I am installing a service door that will give access to the p-trap area of the bathtub.
Thank you
Ahead of time for your suggestions.
Tony
Thank you
Tony
