Mark Alan
This is what I ordered for settings, per your instructions above. CSV will be at 80 with a 70/90 pressure switch. Do I need to do anything different?
That could power a 30 amp subpanel in a shed.I plan on installing a disconnect for the pump power, along with a 12ov outlet. I have 10/3 running to where the pump will be located, so I can do 120 or 240 to the pump. I have not decided on what I want to use. More than likely it will be 240.
The nuts are usually the same size" 3/8 inch.I only turned the small nut about a turn or so. I did not adjust the large nut at all.
Will a garden hose do the 3 GPM? That is all that is currently hooked up at the house. I should have a sink and toilet installed and working by next weekend.
