Copper pipe support under kitchen sink?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tiringer, Sep 5, 2010.
  1. tiringer
    tiringer New Member
    Sep 5, 2010
    Phoenix, AZ
    I am new to the forum, but could not find any thread on this: after installing my new kitchen sink & remodeling, i have the water supply lines (hot&cold) coming vertically from the concrete floor to a height of 24", then a 90 degree with a 4" branch, and finally the shutoff valves. I am worried if this vertical standoff of 24" is too long for my 1/2" copper lines and they might break with time due to the constant opening and closing of the faucet they supply. Is this okay? If not, any suggestions? Do i need to support the copper pipes close to the valves somehow? Thank you.
  2. jadnashua
    A picture might help. If you're worried, they do make supports specifically for this that would support the pipe at the top of the run. The sink faucet should be tight to the counter or sink, and if it is the shutoffs, those only get used when it is time to repair or replace the faucet, so there should be no regular flex or stress on them unless they get bumped with stuff under the sink.
  4. tiringer
    tiringer New Member
    Sep 5, 2010
    Phoenix, AZ
    Thank you. Here is a picture showing my unsupported supply lines behind the drainpipe.
  5. jadnashua
    I wouldn't worry about it...
  6. Fubar411
    Fubar411 New Member
    Nov 15, 2007
    St Louis, MO
    Very good quality 1/4 turn shut offs. Someone was paying attention in class.
  7. hj
    The pipes do NOT move when you open and close the faucets, so you do NOT have anything to worry about.
Similar Threads: Copper pipe
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Monday at 8:27 AM
Plumbing Forum, Professional & DIY Advice 3 Inch copper waste pipe cracked and leaking. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice The beginning of a copper repipe Jan 29, 2017
Plumbing Forum, Professional & DIY Advice Help with Copper Pipe Support Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Aligning Copper Pipe (Visual Included) Jan 9, 2017
