Control motor keeps kicking on and off
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by TXCarl, Nov 2, 2008.
  1. TXCarl
    TXCarl New Member
    Nov 2, 2008
    Control motor making noise, no water
    Water well was working fine. Pump 4 years old, tank not old, new pressure switch. When power turned on it sounds like the control box keeps trying to turn on, making sort of a clicking noise, but no pressure is building up. What does that indicate? If the new switch is not set at a similar pressure as the old one, would that keep it from being able to start pump?
  2. Gary Slusser
    Retired
    Why exactly did you change the switch?
    Did you check the air pressure in the tank with no water in it to be 1-2 psi less than the turn the pump on switch setting? I.E. 30/50 switch settings gets 29-28 psi air pressure with no water in the tank.
Similar Threads: Control motor
Pumps and Tanks Well Forum & Blog. Water is life. 2140 ft pump motor control circuit via float switch..? Aug 6, 2014
Pumps and Tanks Well Forum & Blog. Water is life. submersible motor control box Nov 13, 2007
Pumps and Tanks Well Forum & Blog. Water is life. Have a F&W submersible pump seems to have stopped, replaced QB control box Jan 30, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Confused about pumptec and control box Nov 27, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Franklin Well Control Box Overload Trips Oct 19, 2016
