connecting new yard line
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dedratermi, Aug 18, 2009.
  1. dedratermi
    dedratermi New Member
    Aug 18, 2009
    I have lurked here for a long time but this is my first post. My yard line (between water meter and house) busted so I rented a power trencher and laid a new one. The water is back on again, but I have not yet filled in the trench. I chose 1" PEX for the new line, 85 feet. The water meter output is 3/4" female threads. To attach the PEX to the water meter, I soldered a 3/4" male thread fitting to a short run of 3/4" copper pipe, then a Gatorbite from the 3/4" copper to the 1" PEX. It is working fine, no leaks, but I am wondering if I should bury this as-is or do something else (and if so, what)? Looking for opinions - thanks!
  2. hj
    pipe
    Bury it, but make sure you remove an rocks from the soil around the pipe itself. Did you use 1" PEX because you saw that it had about the same opening as your 3/4" copper?
  4. dedratermi
    Aug 18, 2009
    I used 1" PEX because that's what my neighbors plumber used when his line busted and that's what my town's inspector recommended also. It was also recommended by the plumbing supply shop. I haven't looked at copper prices recently but didn't think I could afford 85' of copper tubing. What would you have used and why?
    I will definitely remove the rocks before burying. But my main question is about burying the gatorbite, is that OK? Thanks!
  5. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    That would be my concern too.
    You know, given some of the failures that I've read about regarding PEX, I would put the PEX in some 2" PVC (pipe or conduit) so that I can easily pull a new piece in if or when it fails. Might save you some trenching later.
    Of course sealing between the 2" pipe/conduit and the PEX could become an issue because any leak would potentially pressurize the 2" pipe/conduit and possibly allow water in to your home.
    Jason
  6. hj
    pipe
    ANything shorter than 100' and 1", or smaller, and I use copper. If it is over those numbers and I use PVC.
Similar Threads: connecting yard
Plumbing Forum, Professional & DIY Advice Help with connecting my dryer up to a water line Dec 31, 2015
Plumbing Forum, Professional & DIY Advice Connecting 1 1/2 PVC to hub Dec 16, 2015
Plumbing Forum, Professional & DIY Advice Connecting ice maker to old copper water line Dec 12, 2015
Plumbing Forum, Professional & DIY Advice Connecting shower drain to a pitched toilet drain, help! Dec 12, 2015
Plumbing Forum, Professional & DIY Advice Connecting new lav drain to existing branch, relocating cleanout Oct 12, 2015
