Confusing shower cartridge
C-Lo
California
Not sure how to get this baby out. It seems the threads are in the way of the nut? The cold side came out like butta.
Stuck hot side:
Working cold side:
The first thng to do is pull that extension off the end of it. Then use the same wrench you used on the cold water to remove the hot stem. That plastic piece makes it look like a Pfister ceramic seal stem.
C-Lo
California
Thanks for the quick response HJ! Ok, so I pulled off the extension and I realized there is a brass increaser stuck in the faucet sleeve. It came off on the cold side with the sleeve but is stuck on the cartridge on the hot side. Any ideas on how to get it off? Trying DW-40 and a channel lock pliers but it's not budging.
CountryBumkin
Active Member
Orlando, FL
You may need to cut a slot across it with a die grinder (or hacksaw blade) and split it to get it off.
Just don't cut all the way through it - just go deep enough to be able to split it in half with a screw driver or chisel inserted in the cut.
C-Lo
California
Country Bumpkin and HJ, thanks, your knowledge saved me hundreds of dollars! I was able to cut off the stuck adapter with my Dremel. HJ, you were right, it's a Pfister cartridge which my local plumbing store had in stock. Shower is all put back together and works like a charm!
