I'd appreciate any thoughts or input on the following options under consideration.
The source is a private well, relevant water analysis is
Calcium 64ppm
Iron .05 ppm
Manganese 0.28 ppm
sulphates 84 ppm
hardness as Calcium Carbonate 307 ppm or nominal 18 grains/gallon
TDS 578 ppm
pH 8.02
Untreated water will have a distinct H2S odour about 3 months after annual well chlorine shock treatment.
Current system is a Star water systems Ultra Pure 11 filter, this uses air injection followed by a 100 gallon air over water contact tank before the filter unit which contains a Birm, Calcite mixture. Claimed to remove iron, manganese and H2S. It doesn't work!!!! I notice Star no longer sell this system. The contact tank is an old galvanized tank and will be replaced whichever option below is chosen.
Following the star filter is a conventional softener and finally a UV sterilization step. Softener works fine. Drinking water is by RO unit on the softened water stream, no problems with this.
House has 3 full bathrooms and 3 half baths but 95% of occupancy is only 2 people.
Maintenance is normal replacement of RO fiters and membranes, salt replenishment, annual well and whole system shock chlorination.
PROBLEM: Occasional slight H2S odour from none RO softened cold water. occurs about 3 months after shock chloination. I'm convinced the H2S comes from iron or sulphate bacteria which re-populate the well over time following shock chlorination and which the Star fiter system, Birm active ingredient, will not remove.
Solution alternatives currently under consideration.
Option 1 the lower cost likely workable
Remove the star filter, the air injector and the old contact tank and install a Greensand filter with Pot. Perm regeneration, then continue to existing softener etc.
Option 2 the highest cost, Bullet proof??
Remove the star filter, the air injector and the old contact tank and install a proportional chlorinator followed by a new 120 gallon contactor tank, followed by a nexsand filter then a carbon filter then on to the softener etc. Possible use of a magox inplace of the nexsand filter.
Comments on the above would be appreciated and any other alternatives gratefully received.
Calcium 64ppm
Iron .05 ppm
Manganese 0.28 ppm
sulphates 84 ppm
TDS 578 ppm
pH 8.02
