Cold pressure changes in Moen cartridge faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chatko, Feb 8, 2008.
  1. chatko
    chatko New Member
    Feb 8, 2008
    Hi,
    I've got a single handle "Cartridge" Moen kitchen faucet (unsure of model number, its been installed for two years.)
    For awhile now we've had problems with the cold water. When i turn it on full it flows fine for 20sec and after that it slows down to 1/2-1/3 of the full flow rate.
    Hot water doesn't seem effected. Cold water in other parts of the home works just fine. Additionally, the shutoff valve for the cold is open to full.
    I've opened the faucet up, taken out all parts, lubricated and reassembled (there was no obvious warn part to my untrained eye).
    Any ideas?
    Thanks
  2. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    It's hard to say what the problem might be. But it could be something like a rock or small metal part in the body of the faucet. It seems unlikely that the diverter (assuming there is one) would be closing with the spray not being used, but the body of Moen kitchens can be plugged easily - there are inner chambers with very small passageways and it's impossible to clean them. In that case, a new faucet would be in order.
  4. jadnashua
    It could be in the supply shutoff valve at the wall if it is a multi-turn one with a washer rather than a 1/4-turn ball valve. Sometimes when the washer gets older, it can swell, or crack, or other things that can restrict the flow. Try removing the hose and then running the output to a pail or something.
Similar Threads: Cold pressure
Plumbing Forum, Professional & DIY Advice Need to decrease pressure on the cold side Apr 16, 2016
Plumbing Forum, Professional & DIY Advice Low cold water pressure Feb 22, 2015
Plumbing Forum, Professional & DIY Advice Low Cold Water Pressure in Entire House Jun 18, 2014
Plumbing Forum, Professional & DIY Advice Typical Difference in Hot Water and Cold Water Pressure Mar 29, 2013
Plumbing Forum, Professional & DIY Advice Need question answered about water and pressure and cold outside (if that makes sense Jan 23, 2013
