Code Question: MC cable touching copper water pipe in ceiling. Problem?
Discussion in 'Electrical Forum discussion & Blog' started by PabNYC, Oct 30, 2008.
  1. PabNYC
    PabNYC New Member
    Dec 5, 2004
    NYC
    It is an easy fix either way but a contractor was at my house the other day and mentioned that in the ceiling the MC cable was touching the copper water lines and it was a problem.
    Is this:
    A: A problem (code violation?) and why?
    B: Not a problem
  2. jar546
    jar546 In the Trades
    Feb 20, 2008
    USA
    Any metal touching copper will eventually be a problem due to corrosion and oxidation. Don't let it touch it.
  4. hj
    wire
    Our inspectors do not want ANY electical wire touching a plumbing water line. And are not too crazy about drain lines.
  5. PabNYC
    PabNYC New Member
    Dec 5, 2004
    NYC
    In most areas I can just secure the electrical cable tighter to the ceiling with clamps but in tighter areas would it be sufficient to use the foam pipe insulation to prevent contact between the two?
  6. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    This is not a code problem
  7. jar546
    Feb 20, 2008
    USA
    Not necessarily, it depends on what the MC is touching or exposed to.
    NEC 330.12(4)
  8. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    330.12 Uses Not Permitted.
    (4) Where subject to cinder fills, strong chlorides, caustic alkalis, or vapors of chlorine or of hydrochloric acids
    Damn, I thouhgt you were for real for a second but then I came back to reality.
    What the original poster asked is in no way a problem except is the mind of some untrained, uneducated guessers.
  9. sparkie
    sparkie In the Trades
    Oct 5, 2008
    Master Electrician
    Problem?
    There is no code violaton here. Personally, I would prefer for MC not to touch the copper water pipe. Often this is where corrosion is seen. Perhaps due to different types of metal.
  10. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Seems the sparky's up here think our pipes are for supporting their wires. Gets really annoying once the home theater guys have followed suite along with the central air pipes basket weaving through all the PEX, too. :mad:
  11. hj
    sparky
    What's really annoying is when you predrill your holes and the electricians think that is a convenient place to run their wires through. Or, that the center of a 4" wall is the best place for their Romex or conduit, especially if they can see a plumbing pipe coming out of the floor right beneath it.
  12. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I like when they mount their panel above the stubs in the slab for the water and sewer lines...
    Thats rocket science!
  13. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    Oh give me a break you guys. Plumber are FAR worse with the "I am the only one on the job" mentality.
    BTW HJ, YES, the center of a 4" stud IS the ONLY place to run the wire.
    A) ANY electrician who uses a plumbing pipe to support his wires is a hack.
    B) ANY electrician who uses someone else's drill holes in framing is a jerk.
    3) ANY electrician who puts a panel right above pipes stubbed out of a slab is either a dumbass or was told to do so by the builder.
    What about the plumber who runs a vent stack from a bath vanity sink right straight up from the sink, knowing full well that there will be a vanity light dead center over the sink?
    It goes both ways guys, and out stuff is WAY more flexible that yours, remember that. You can push a wire out of your way, I cannot mount a pancake box right to your vent stack!
  14. kingsotall
    Aug 17, 2008
    Left out, "that matters." :)
  15. TheElectricalGuru
    TheElectricalGuru National Electrical Code Expert/Speaker/Educator
    Oct 10, 2008
    lol....man I get a chuckle when I read some of these posts...lol.....
    NO it is not a violation of the NEC, and what I think someone was trying to make reference too was 110.14 in regards to dissimilar metals....BUT since we are not talking about terminations.....who cares....110.14 would not apply ANYWHERE in that question....
    so.....yet again as far as the NEC is concerned...no violation of the MC touching the metal waterpipe.....and hopefully if they DO have metal water pipes they have done their work to meet 250.104(A)(1) anyway....no worries.
  16. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    From a carpenter's view... electricians and plumbers BOTH suck, and NEITHER ought to be allowed near a sawzall!
    :D
    But seriously... there's nothing on this in the electical codes, but isn't there something in the plumbing code? I know they have to use copper hangers on copper pipes, and you're supposed to use copper nails in those hangers... same logic, no? Dissimilar metals = corrosion?
    Might want to cross-post this in plumbing.
  17. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    Frenchie where you been?
  18. jar546
    Feb 20, 2008
    USA
    Although in this case it is not a code violation, it should be addressed so it does not cause a problem in the future.
    Remember, codes are minimum standards, minimum. The electrician was right to point this out.
  19. TheElectricalGuru
    Oct 10, 2008
    Jar,
    May I ask what problem it will cause if it did touch? Considering the galvonic reaction usually takes a catalyst to happen I guess I would be interested in knowing what you think would happen in a closed ceiling and a MC touching the pipe?
    Not being a SmartA$$...just wanted your view on it.
  20. jar546
    Feb 20, 2008
    USA
    My view is that I have inspected thousands of homes from brand new to ove 200 years old and found that in many cases whenever the two metals touch there is a problem. Whether pinhole leaks that start by simply rubbing the copper with your fingernail to the already fragile soldered copper connection deteriorating then being accelerated with the addition of a disimilar metal.
    What may be approved by code or still works a couple of years later may be a problem in a few more years.
    I once found a pinhole leak cause by a twist tie from a garbage bag that for whatever reason was placed on a section of copper pipe.
    Depending on where you are from, the quality of the water that runs through your pipes and whether or not it is from a well or public water may cause your mileage to vary.
    One of the best ones was a very expensive fix after the EGC clamp on a water main deteriorated the pipe until it burst when no one was home. It was a finished basement.
    Many of you may be very familiar with new installs but I am looking at piping systems that are at or near the 100 year mark. Many of the leaks that I find are from homes that are not that old, especially when they have well water and a very low pH and a high iron content which is more than common in my area.
    So no code says you cant do it but is it so hard to move it out of the way or do we need to make an issue from a 10 second fix opinion?
  21. xroad
    xroad New Member
    Oct 12, 2008
    Eh ... Sorry to interrupt ..... What is MC? New at this stuff, still learning.
Similar Threads: Code Question
Electrical Forum discussion & Blog Bathroom remodel code question Jun 7, 2016
Electrical Forum discussion & Blog Electrical code questions. 2005 NEC Jun 15, 2015
Electrical Forum discussion & Blog Code question 277 and 24 volts same fixture. Sep 27, 2012
Electrical Forum discussion & Blog Code Question: Safely Storing Future Use Wires Jul 31, 2012
Electrical Forum discussion & Blog Code question on multi-location dimmers ( lutron / maestro ) Dec 28, 2009
