Clueless Newbie Full Bath Reno... Oh Noooo!
Discussion in 'Shower & Bathtub Forum & Blog' started by duct tape pro, Apr 17, 2007.
  1. duct tape pro
    duct tape pro New Member
    Apr 17, 2007
    Edmonchuk Alberta
    Well, this looks like a job for something bigger than duct tape. Dang!
    Just about to start ripping bathroom apart to put all new stuff in.
    First out is a 1 piece tub/surround in beautiful harvest gold.
    Anybody remember these???
    Anyways, any obvious tips on how to avoid stupidity is appreciated.
    Assumptions on tub from what I"ve read.
    1. turn of water before starting
    2. Use reciprocating saw to cut tub into pieces to get out of room.
    3. disconnect taps, drain.
    Now, can drain be disconnected from sitting in the tub? There's now way to see what's underneath without cutting wall.
    I am hoping it's like a sink drain where you can spin the top to get it off somehow. (I am guessing there's some of that putty stuff under the chrome drain lip too?
    Also it looks like I've got to whack some drywall to get the flange that holds tub in place? correct?
    Any tips appreciated while I sip a beer here getting psyched for the weekend. :eek:
  2. jadnashua
    There is a flange behind the drywall around the tub, so you will need to break some of that out. Some tub drains can be dissassembled by turning out the strainer from the top. If it is a pain, consider just cutting around it and remove the tub and getting it later.
  4. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    block P trap to prevent crumbs and debris from falling into it. You don't want that stuff in your drain plumbing. You can use rags.
    Later, don't use vacuum cleaner at tail end of clean up.
    david
  5. hj
    tub
    Sawing the tub apart is going to create a lot of fiberglass "dust", so be sure to use breathing mask so you don't inhale the fibers.
  6. duct tape pro
    Apr 17, 2007
    Edmonchuk Alberta
    Gee, cutting around sounds too simple. Great idea.
    Q1. Is the P trap the curved pipe under the tub drain before it goes off to sewer system?
    I've got a great mask.
    One thing I'd like to share is suggest people wear proper masks (not the coffee filters with a rubber band attached) when busting drywall too. Before 1980 some drywall contains asbestos which could lead to mesothelioma. I've seen that and it's not nice.
    Q2. I am guessing the on/off valve for the shower/tub taps is hiding in the wall somewheres, so I'll have to cut a hole on the other side of the wall?:confused:
  7. jadnashua
    Yes, the trap is the curved drain section. Often, you can take the handles and trim off of the valve, then pull the surround out from over them. Eventually, you'll probably want to replace that valve. You could cut it off and cap the pipes until ready, or just leave it there, just don't bend it and crimp the pipes.
Similar Threads: Clueless Newbie
Shower & Bathtub Forum & Blog Installing a handheld shower with Ell (Newbie) Jul 31, 2014
Shower & Bathtub Forum & Blog Newbie : Miracle Method resurfaced my 1985 tub and now have same problem Jun 9, 2014
Shower & Bathtub Forum & Blog Need help with leaky bathtub faucet - newbie Sep 30, 2013
Shower & Bathtub Forum & Blog newbie tub (tile) install question Feb 11, 2013
Shower & Bathtub Forum & Blog Plumping newbie, need help identifying faucet/steam and removing a diverter from such Oct 7, 2012
