Clogged Kitchen Sink w/ Waste Disposal Unit
John Thompson
Elk Grove Village, Illinois
I have a clogged kitchen sink drain. This kitchen sink has a waste disposal unit attached and seems to back up nearly completely (drain so slow you can't notice the water going down) but once the disposal is run it drains very quickly. After cleaning the trap I ran water through just the waste disposal unit into a bucket and it didn't seem to back up at all. I suspect there must be a clog somewhere in the drain pipe but why would it then drain so quickly with the disposal on? Any advice is appreciated!
Montreal, Canada
Waste disposals usually clog pipes quicker, since users introduce all sorts of stuff into the drain other than greywater that normally wouldn't go in there.
Fatbergs usually clog kitchen drains from the area after the trap, all the way to the verticle.
If you have a modern p-trap, remove it by uncoupling the hand nuts at both ends of the trap. Don't try to auger it through the trap's plug, we want to reduce the bends of an auger path.
Auger ends usually get stuck from a bend. If you think this may be happening, try a simple 1/4" drain auger, they are more flexible than the drums.
I like to give hope to chemicals when they may be the last line of defense before digging up a trap encased in concrete. As for soft ABS that is easily accessed, it's simple and inexpensive to cut it all away with a new install.
SteveW
DIY Senior Member
Omaha, NE
A product which does work is called Bio Clean. Terry sells it on this site. It has bacteria and enzymes that "eat" the "fatbergs" (yummy!)
Takes a few days to a week or two but I've had great luck with this product as long as a drain isn't completely blocked. It also has instructions for cleaning out the disposer.
A little pricey ($50 as I recall last time I bought some here) but lasts years, safe, and effective.
John Thompson
Good to know what is likely a waste of time and what isn't. I'm going to give another try with the auger. And if that fails me I may try this product you've mentioned. When you say it takes up to a week do you need to pour some down each day? Can you still use the drain while it's being treated? Thanks for all the help...this message board is really helpful!
SteveW
DIY Senior Member
Omaha, NE
Basically, with the enzyme/bacteria products, you do mix some up every day for 3-7 consecutive days or until the drain seems to be back to normal. Some are liquid but Bio Clean is a powder that you mix with warm water, then pour down the sink. You have to leave the sink unused for the next 8 hours to let the little critters do their work. Apparently once they get a foothold in the fatty deposits on the sides of the pipes, they can keep reproducing on their own. Unlike the lye-based drain cleaners, Bio Clean will actually get the whole circumference of the pipe clean eventually.
JohnPeter
California
I am installing salon-style hair traps everywhere... including kitchen double sink. These are transparent and employ a sieve. It helps to install these straight down from drain opening, so one can pump them dry with simple hand pump before opening the trap up; thus very little water will spill out.
Those traps violate EVERY principle and requirement for a sink trap.
1. They are NOT "self cleaning"
2. The trap is NOT supposed to accumulate "debris"
3. The trap is supposed to have a "smooth" interior.
4. The fittings required to install the trap could be the cause of it plugging up.
