cleaner vs primer
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by steelers fan, Jan 10, 2010.
  1. steelers fan
    steelers fan In the Trades
    Dec 11, 2009
    va
    i screwed up the other day redoing a retired union plumbers kitchen sink pipes at least i think.I accidentally grabbed a can of clear pvc cleaner I had on my truck thinking I had grabbed clear primer.I realised it after a couple of joints and switched over to primer.It was getting late so I left it for now but am going back tomorrow to cut those two fittings out and redo them correctly.But i figured id ask if you guys if these joints would actually fail,im sure they will but at the same time when reading the cans of cleaner and the primer they list the exact same ingredients.Anyone have any input on this?thanks
    p.s. brown can and yellow can i must be going colorblind
  2. jimbo
    jimbo Plumber
    I wouldn't change it. Primer is similar to cleaner....just more agressive.
    Plenty of sprinkler pipe is installed with neither! For DWV, your joints should be fine.
  4. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    Primer has a dye in it so inspectors can tell it has been used. I agree no problem on DWV.
  5. steelers fan
    Dec 11, 2009
    va
    thanks guys went there today and filled both sinks and let er run no problems Ive just never used cleaner at all before only had it cuz i got a lil sloppy with purple primer.No leaks and got to swap out the old globe valves under his sink too( no angle stops ).So it was a slow day but all good.Thanks for your help
  6. jetlag
    jetlag New Member
    Dec 12, 2009
    Ga.
    No Problem
    I wish I had a dollar for every pvc joint thats holding fine glued with only the cement. Ive been guilty few times myself even on supply pipes when in a tight and had no cleaner or primer . Ive never had a problem with that.
  7. steelers fan
    Dec 11, 2009
    va
    I just left a house the other day where a guy used nothing but glue and before he got there the tub overflow and drain dripped after he left it poured;)
  8. jadnashua
    The cleaner/primer not only takes the crud off, but also softens the surface a little so the cement can melt and fuse the pipe into the fitting better. I think it somewhat depends on how much of the solvent has evaporated out of your can (i.e. an almost empty can has probably lost a bunch of the solvent) - when new, probably won't notice much, but you are likely to if at the end.
  9. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    You don't wan't that 2 AM CALL
    cut it out , it is not the same
  10. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    I have seen some so called plumbers mix some primer with the glue to give it the purple color.
    John
  11. toolaholic
    Jul 16, 2005
    Marin Co. Ca.
    Cheaters never prosper !!
Similar Threads: cleaner primer
Plumbing Forum, Professional & DIY Advice Cleaner/primer with abs? Jan 30, 2007
Plumbing Forum, Professional & DIY Advice Liquid Fire drain cleaner question Jan 6, 2017
Plumbing Forum, Professional & DIY Advice My Weekend Adventure with Enzyme Drain Cleaner - Long Read Dec 6, 2015
Plumbing Forum, Professional & DIY Advice Bio Based Cleaners Jul 25, 2015
Plumbing Forum, Professional & DIY Advice What Calcium Buildup Cleaner is Safe to Use on Toto Nano-Finish Toilets? Oct 25, 2014
