clawfoot tub leg problems
Discussion in 'Shower & Bathtub Forum & Blog' started by Boots, Mar 27, 2007.
  1. Boots
    Boots New Member
    Mar 27, 2007
    waterfront sales
    Irvington,VA.
    Need help FAST!
    My tubs legs do not attach to the tub, the tub just sits in place on the legs. The problem is the legs keep moving, even with the tub weight. What would be the best (safest) solution to the stabilization of the legs/tub?
    Thanks
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Are all four legs bearing equal weight, or do you possible have a wavy-floor problem? Also, is the floor surface hard, soft, slippery ...?
  4. Boots
    Boots New Member
    Mar 27, 2007
    waterfront sales
    Irvington,VA.
    The floor is new, level and tile. It is slippery. The tub sits level. I was thinking about connecting the front 2 legs together, and the back 2 together, from the bottom of the tub. This might keep the pressure on them. Then maybe some kind of glue, or bond for iron?
  5. leejosepho
    Nov 23, 2006
    I have no experience with footed tubs, but keep in mind that "level" and "flat" are not always the same thing. Your tub's stability might well depend upon each leg bearing exactly the same amount of weight as well as not being able to slide on the floor, and if you check closely, you might presently find one leg you can wiggle just a bit ... but maybe somebody else knows about your type of tub and what it takes to make it stable.
  6. Boots
    Boots New Member
    Mar 27, 2007
    waterfront sales
    Irvington,VA.
    Good morning,
    I still need advice...?
    HELP
  7. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    your description in post #1 is not clear to me.
  8. Cass
    Cass Plumber
    Nov 12, 2005
    Is this a cast iron tub or fiberglass or what???
    Can you post a pic?
  9. Boots
    Boots New Member
    Mar 27, 2007
    waterfront sales
    Irvington,VA.
    Sorry...it is a 1937 cast iron tub.
  10. geniescience
    Nov 27, 2005
    ditto
    70 years history here
    what was the situation in the last seventy years? What changed for the worse?
    Why the haste?
    There are many ways to skin a cat. I don't believe anyone can prescribe anything close to perfection.
  11. Boots
    Boots New Member
    Mar 27, 2007
    waterfront sales
    Irvington,VA.
    I totally gutted the old room. It was built over a porch. Bad shape. Now the floors are level with a new tile. The legs were set, then we installed all new Strom fixtures. When we were in the tub adding the shower ring and the legs started to move. When we tried to adjust them they all started to move! They lock in the back, but they are sliding outwards of the tub. I felt if we pulled the legs from the middle of the leg inwards, this would keep them locked in place. Then glue/bond?
    The reason for the hurry is I don't want the kids, or the cat, to move the tub and all fall. Something so simple but...
    I did add new Toto tolets. They are great!
  12. casman
    casman New Member
    Sep 8, 2004
    New York
    Maybe I'm missing something, first you said they just sit undet the tub, later you said the back one's lock in place, most of the Old ones I've seen slide into a wedged area with a set screw underneath. If there are no set screws, maybe you could drill, tap, and install some.
  13. jadnashua
    I've never dealt with one of these so take this for what it's worth! If the legs have a tapered slot, maybe they need a gentle persuasion to lock in place. It would make some sense that there would be a set screw or a locking bolt to hold them. Sure there's not threaded hole on the foot or the attachment point to perform this task? Course sticking your arm under a 3-400# tub has its dangers...you might want to place some blocking under it just in case while you're playing with it.
  14. Boots
    Boots New Member
    Mar 27, 2007
    waterfront sales
    Irvington,VA.
    I used braded wire to pull the legs into the proper position, then JB weld on the under side and gorrilla glue around the outside. There was NO screw on this model. This will hopefully take care of the problem...
  15. cococola
    cococola New Member
    Apr 6, 2011
    California
    Unsecured clawfoot tub feet
    Try propoxy 20 epoxy putty. www.herchem.com
  16. missniceguy
    missniceguy New Member
    May 8, 2012
    blood-sucking bass player, yes, literally! =D
    ontario, canada
    hi all, i'm new here, thanks for welcoming me aboard! =D
    i have a 1927 clawfoot which is almost ready to place ... three of the legs have just a little play in them but the fourth has much more ... i've gotten plenty of advice (conflicting, of course! =D)
    can anyone suggest what is best to level this tub's legs before i haul the behemoth inside? my instinct is to leave well enough alone & not cut the bolts, but ...
    should i cut the bolts & retighten to level? (how do you level them, then?)
    should i leave them in place & shim the fourth leg? (once again, how do you level it?)
    is there an easy way to do this or am i in for a ride? =D
    can't wait for that first soak!
    thanks much ... XoX
  17. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    I've never seen a clawfoot that had a leveling feature built-in. Wait until the tub is in place on the finished floor, then shim
    as necessary until it doesn't rock (which will not always mean LEVEL).
Similar Threads: clawfoot problems
Shower & Bathtub Forum & Blog Clawfoot bathtub gurgles Yesterday at 12:45 PM
Shower & Bathtub Forum & Blog Very stubborn spud/shoe on old clawfoot Jul 20, 2016
Shower & Bathtub Forum & Blog Clawfoot tub faucet knobs turn on their own May 12, 2015
Shower & Bathtub Forum & Blog How to replace a clawfoot tub faucet and waste and overflow Oct 18, 2013
Shower & Bathtub Forum & Blog Clawfoot tub installation with pex stub outs Aug 6, 2013
