Datarock
- Messages
- 10
- Reaction score
- 0
- Points
- 1
Hey everyone. The wife moved before I did (had to finish out work) and the water softener was installed before I arrived. Now that I am here I have looked over the settings and want to ensure the brilliant minds of the terrylove forums agree they are the "ideal" settings.
I have not completed a water test but the annual report stated that the water in this area had hardness around 20 gpg.
I am not positive on how large the mineral tank is though. The measurements I took are approx 55" tall and 9" wide. I also took a few photos for you all.
It is only my wife and I and according to two months of water bill service we hover around 3000 gallons a month. (We have solar panels and try to be eco friendly so everything is low pressure faucets/showerheads etc.)
Here are the settings that the installer programmed into the unit.
Days between Regen-13
Energy Saver-On
Water Hardness 20GR
Softening DN Pre-Set TYPE
Fill-Set 12.0LBS
Softening Time-Set 240:00
Backwash Time-Set 8:00 Min
Draw On Time SET 60:00 Min
Grains of Capacity-Set 33.0 x1k (I thought I had a 36k unit but maybe not)
Gallons Capacity-Set Auto
Delayed-Set Regen
Off-Set Relay 1
Off-Set Relay 2
That should be it.
Please let me know if you need any other information from me.
Thanks so much everyone,
Ron
Energy Saver-On
Water Hardness 20GR
Fill-Set 12.0LBS
Delayed-Set Regen
Off-Set Relay 1
Off-Set Relay 2
That should be it.
Ron
