cistern pump system
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by alkajd, Jan 24, 2009.
  1. alkajd
    alkajd New Member
    Jan 24, 2009
    I have cisern that's under my garage floor an the swallw well pumpis in the basement next to it I have a tank but it's not a pre-charged pressure tank. The problem is the pump short cycles a lot when I'm not dischargeng water A) How do I stop this? B) Do I need to add a pre-charged tank and how do I size it?
    Thanks
    alkajd
  2. WV Hillbilly
    WV Hillbilly New Member
    Aug 1, 2008
    WV
    If your pump is running when you're not running any water you probably have a leak . When you say you're not discharging any water I assume you mean no faucets are open & you're not running water anywhere .
  4. sammyhydro11
    sammyhydro11 Previous member
    Dec 20, 2006
    Well Drilling-Test Borings-Water Treatment-Well an
    Massachusetts
    It is short cycling because the pump has no place to displace water or store it once you stop running water. The short cycling will wipe out the starting mechanism on the motor. You will need to install a diaphragm holding tank on the discharge side of the pump. If you have one in place it is either no good or it needs air.
    sammy
    www.tylerwellandpump.com
Similar Threads: cistern pump
Pumps and Tanks Well Forum & Blog. Water is life. Jet Pump Cavitation With CSV / Cistern Dec 5, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Cistern pump tripping breaker. Jul 1, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Submersible pump failure in cistern Jun 5, 2016
Pumps and Tanks Well Forum & Blog. Water is life. submersible pump in a cistern Mar 5, 2016
Pumps and Tanks Well Forum & Blog. Water is life. How to best control well pump and cistern Sep 23, 2015
