Chrome Sleeve for Angle Valve Flange?
Discussion in 'Toilet Forum discussions' started by BS, Jun 22, 2007.
  1. BS
    BS New Member
    Jan 21, 2007
    Central Ohio
    My existing angle valve (shut off valve) for my toilet is a bit corroded, especially the chrome plated PIPE (brass?). I know I could heat it and remove it and sweat a new one on, but I'm concerned about two things. One is that the copper stub-out coming out of the wall is curved to form a smooth 90 degree bend (no elbow fitting) so I'm presuming it's flexible copper with which I've never worked before. The other is that a few years ago I had a lot of trouble sweating a new chrome plated angle valve PIPE to another stub-out.
    Is there any difference in working (sweating) with flexible copper pipe versus rigid pipe? Do I have to do anything different when sweating a chrome plated PIPE?
    Instead of replacing the valve, is there some kind of chrome sleeve I could simply slide over the corroded PIPE?
    - Bernie
  2. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    You can use a tin snips to cut off the corroded escutcheon plate and replace it with a new one that opens and closes using a hinge mechanism that you can install without having to remove the stop valve.
  4. BS
    BS New Member
    Jan 21, 2007
    Central Ohio
    Thanks, Eric. I should have mentioned I have one of those hinged escutcheons. It just occurred to me that I used the wrong term. (My apologies. That's what I get for trying to squeeze in a question to the forum after a long day!). What I'm actually referring to is the 4 to 5 inch long chrome plated pipe behind the stop valve. Are there any sleeves or covers that can go over that?
    - Bernie
  5. Verdeboy
    Jun 12, 2006
    I'm not aware of such a pipe. Can you post a photo?
  6. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    I think what your talking about is a "Chrome plated cover tube" it is 1/2" x 3-1/2" and goes over copper pipe.
    I know Brasscraft makes one it's a #8489C and the flange your refering to is a "Split Flange".
  7. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Buy one of those plastic white/beige colored supply covers meant for handicap accessible required lavatory faucets.
Similar Threads: Chrome Sleeve
Toilet Forum discussions Nominal 1/2" supply line chrome over copper? Dec 6, 2015
Toilet Forum discussions Where can I get the least expensive chrome replacement trip lever for our CST744SL? Jan 2, 2015
Toilet Forum discussions Large Brass (or Chrome-Plated) Slip Joint Nuts Jan 21, 2007
Toilet Forum discussions Chromed Pipe ? May 13, 2006
Toilet Forum discussions Replace toilet chrome handle with a Dec 23, 2004
