I have a 600 foot submersible that pumps into a cistern at atmospheric pressure. It appears the check valve has gone bad, because I used to be able to lift the float switch to manually turn it on (just checking operation from time to time) and water usually starts flowing within 2 seconds; this time it didn't turn on. I go inside to grab my meter to check for voltage and I come back out about 5 minutes later and the water is flowing. My assumption is there is a check valve down at the pump that has probably failed. Now for my question: can I install a check valve at the surface? Would that be a decent band aid, as I do not possess the equipment nor skills to pull the pump out and replace the valve, nor do I want to pay to have it replaced when a 15 dollar check valve can be easily placed at the surface.
