Changing shower hardware
KathyRN
I want to change the shower and tub fixtures. The old shower head has a ball valve so I will need to get back behind the tile to do this. There is a linen closed adjacent and should provide access. Do I just cut the sheet rock to see what is behind there? This will be a new plumbing experience for me. I have done fine replacing lines to other projects and have replaced the bathroom and kitchen sink fixtures without problems. My spouse can do everything EXCEPT plumbing (as there is always a leak). Does anyone have any tips before I dive in to this project?
Verdeboy
You might be able to just enlarge the hole in the ceramic tile a bit to unscrew the old shower head. Try a dremel or rotozip with a carbide bit. Wear eye protection.
You can also use your dremel or rotozip with drywall bit to make the access panel, if you choose to go that route. Set the depth to slightly greater than the thickness of your drywall.
shower
What, exactly, are you trying to change. If it is just the shower head, then even though it has a ball on the end, it is still just screwed into the pipe in the wall and you do not have to cut anything to unscrew it.
