Cement board or DensShield??
Discussion in 'Shower & Bathtub Forum & Blog' started by Fistor, Jul 14, 2008.
  1. Fistor
    Fistor Geotechnical Engineer
    Mar 18, 2008
    Vancouver, BC
    Hi -
    Looking for opinions on the usage of cement board vs. DensShield behind tile for a tub enclosure.
    My understanding:
    cement board:
    - durable
    - allows moisture through, but provided that you have waterproofing behind it, it won't be a problem.
    - more difficult to work with than DensShield
    - worse looking finish if you wish to paint portions of the cement board (outside of the tile extent), even if you prime then place drywall compound over as a base for the paint
    DensShield:
    - light
    - water resistant - provided that the surface covering remains intact
    - easy to work with and finish (compared to cement board, that is)
    - can degrade if moisture gets in
    My inclination is towards the cement board, despite the finishing issues I may face later - after all, if the DensShield ultimately gets wet and degrades, then the finish doesn't matter anyway), but I wanted to hear what all of you had to say.
    What do you think?
  2. jadnashua
    I'd use the cbu...no mold food, won't degrade if it does get wet. You could apply a surface waterproofing like RedGard if you wish. CBU will absorb moisture if it gets to it, but will not degrade. Make sure to use the special mesh tape on the joints. You can apply this while tiling, it's for strength, not for show like on drywall - you don't want a hump there, so installing the tile while it is in the soft/pliable thinset prevents 'speed bumps'.
  4. rbird7282
    rbird7282 New Member
    Jun 29, 2008
    I would use a product called Wedi board. It is 100 percent waterproof and very lightweight. Easy to work with. Won't degrade.
Similar Threads: Cement board
Shower & Bathtub Forum & Blog Two layers of cement board? Jun 24, 2016
Shower & Bathtub Forum & Blog Potential problem with cement board installation Jun 6, 2016
Shower & Bathtub Forum & Blog Cement board/drywall dilemma, need help Aug 31, 2015
Shower & Bathtub Forum & Blog Waterproofing bathtub cement backer board Jul 6, 2015
Shower & Bathtub Forum & Blog How big, if any, should the gaps be between cement board when using for tile backer? Apr 13, 2013
