Celing Fan wiring
Discussion in 'Electrical Forum discussion & Blog' started by crabapplemcn, Dec 2, 2008.
  1. crabapplemcn
    crabapplemcn New Member
    Oct 29, 2008
    I am building new construction and will have an electrician hard wire but will install ceiling fan myself. I wanted to have 2 wall switches control the fan. One to control the light and another (knob) to control the various speeds of the fan. Is that possible and if so, how does it need to be wired
    (anything special) and what wiring must the fan have (I have seen 2 wire vs 3 wire options when purchasing fans)
    thanks
  2. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    That depends entirely on the way the variable-speed controller works. If it's continuous, like a rheostat, you can get away with 3 wires (plus ground) from the switch to the fan (neutral, light, fan). If it's a multi-speed control, like low-medium-high, then you will probably need a separate wire for each speed, plus the one for the light, plus the neutral and ground.
  4. jar546
    jar546 In the Trades
    Feb 20, 2008
    USA
    It is best to simply run a 3 wire so you can have 3 switches.
    Most quality fans these days actually have remote control devices at both ends and you can completely control the fan from that. The remote control will be installed inside the canopy of the fan.
    Just go to an electric supply house and tell them what you want and they will direct you.
    You may not even need the 3rd wire but have him pull it anyway, just incase you buy a cheap piece of crap.
  5. jadnashua
    My (ancient) Cassablanca fan controls fan speed, direction, light and dimmer with a two-wire circuit but requires their controller. Haven't looked at anything recent.
  6. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    Always, ALWAYS run a 3 wire cable to a ceiling fan.
    Generally it is a 14/3.
    When you hang the fan, use the black for the fan and the red for the light. Black/black (fan motor), red/blue (light kit)white/white (common/neutral), green/bare (ground) Hunter brand fans use black for fan motor and black/white stripe for light kit.
    I think you meant two switches rookie ;)
  7. jadnashua
    In my case, I was replacing an overhead light with a fain/light combo and wanted to control the light and fan. The cassablanca does that electronically with only the two wire circuit. If you are running a new wire, the extra wire gives you a lot more flexibility.
  8. jar546
    Feb 20, 2008
    USA
    yes,............why yes I did
  9. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    huh ???!!!???
  10. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Yup. I've seen older fans with (apparently) multi-tapped windings and low-medium-high switches to set the speed. You'd need a common plus one wire for each speed if you wanted the switch on the wall, instead of on the fan. I'd be really surprised to find one for sale anywhere today, but I've been surprised before.
  11. frenchie
    Dec 30, 2006
    Caretaker
    Learn something new... every day.
Similar Threads: Celing wiring
Electrical Forum discussion & Blog Underground UF Wiring Gauge Selection Wednesday at 7:29 PM
Electrical Forum discussion & Blog Wiring Split 15 & 20 amp circuits on same receptacle Wednesday at 7:05 PM
Electrical Forum discussion & Blog Need help wiring ceiling fan! Feb 15, 2017
Electrical Forum discussion & Blog Strange Dimmer Switch Wiring Jan 6, 2017
Electrical Forum discussion & Blog Doorbell Wiring Dec 29, 2016
