Ceiling supplies and Kohler K-303 Why Not?
leorob
Los Angeles
I am remodeling a shower and will be installing a Kohler k-303 Three valve shower valve (Hot, Cold & diverter).
For some reason the instructions say that I cannot use this valve with ceiling supplies.
I could certainly re-route the copper and bring the supplies in from below, but, for the life of me I can't figure out why they say not to use the three valve yoke with ceiling supplies.
(The also make a two valve yoke {without the diverter} and there is no such warning for this one).
Any ideas?
Hate to burst your bubble, but unless I've overlooked it, that valve will NOT pass inspection on a remodel or new installation - it does not have the mandated anti-scald technology REQUIRED by code. Save yourself some hassles, ditch the Kohler, and install a different brand. Kohler changes their designs on a whim, and getting parts is really tough, not counting the code issues. They do make valves that will pass code if you decide to stay with them.
leorob
Los Angeles
Your are correct....but
You are correct to a point.
Since I am replacing an existing 2 handle shower whose valves have gone bad, the city will let me install the valve in question.
If this were new construction, OR a major remodel you would be correct.
They will not force a homeowner to redo tile in a case like this.
So, my question remains....Why no ceiling supply?
Jimbo
San Diego, CA
well, ceiling supplies might imply that you would turn the valve upside down for easy entry, and it may have a restrictor in the "up" outlet.
If you can get inside the wall to install a new 3 handle valve, seems like you could install a single handle, with a smitty trim of course.
I am surprised that Kohler still makes a 3 handle. PP does, but I am pretty sure the Moen and Delta do not.
valve
You can use ceiling supplies, you just have to drop them below the valve and come up into it from the bottom. With a 3 valve diverter, inverting it would reverse the operation of the diverter handle.
