Caulking New Tub Valve and Spout
Discussion in 'Shower & Bathtub Forum & Blog' started by frodnew, Nov 18, 2005.
  1. frodnew
    frodnew New Member
    Jan 29, 2005
    Michigan
    Just had a plumber install a new shower mixing valve and spout. He recommended caulking around both the spout and the valve. The spout advice seemed pretty obvious. But the valve has the foam seal on the backside of the cover plate. What to the pros do? Is this foam seal adequate? Could plumber's putty behind the mixing valve cover plate replace caulk on the outside?
    Bruce
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    calk
    I would loosen the cover plate and put an excessive amount of plumbers pitty under it. When you draw it up with the cover screws excess putty will come out.
    Take the spout off and putty the hole that the spout nipple comes through.
    Now take some Polyseamseal and wipe it around the fixtures with a wet cotton cloth.
    Works for me.
Similar Threads: Caulking Valve
Shower & Bathtub Forum & Blog Shower door rail has openings INSIDE the shower? Ruining caulking. Feb 20, 2016
Shower & Bathtub Forum & Blog Caulking around trim sleeve? Feb 13, 2016
Shower & Bathtub Forum & Blog Help, shower leaking around tile and caulking gap Dec 26, 2015
Shower & Bathtub Forum & Blog Is caulking necessary? Jun 16, 2013
Shower & Bathtub Forum & Blog Leak under base of corner shower stall doors after cleaning, re-setting and caulking Mar 30, 2013
