Can't get trim off shower handles... advice?
rrr
California
Hi,
I have a Delta tub/shower faucet setup. Probably 10+ yrs old. Don't know the model number.
I'm trying to get the %#&^ trim off the handles... but they won't budge. Tried unscrewing them, pulling... but it doesn't budge. How do these things come off?
Here's a picture of the trim I'm trying to remove.
thanks!
Smooky
North Carolina
If you don't see any set screws, I would try to unscrew it. Put something that fits tight inside the trim so it does not get distorted. A socket might fit. You can always wrap something around the socket to help it fit tighter. Then grip the trim sleeve where the handle covers the trim so any scratches don't show.
rrr
California
Thanks for the reply. Makes sense. So I found a socket that fit well, then grabbed it with a big set of pliers... and gave it a good try. But still didn't budge. All I can figure is that the threads are rusted/corroded. Probably dissimilar metals reacting/fusing....
I'll squirt some liq wrench into the threads, let it sit overnight and and try again tomorrow.
thanks again
I am glad some one told you it is (Price)Pfister, otherwise you would get the wrong parts. Put the proper sized socket INSIDE the sleeve and then grab it and twist. I have NEVER had them not come loose, but IF they did not, then the whole stem would come out and you could replace it. Call 1-800-PFAUCET for any replacement parts. I cannot tell if your stem has a white plastic "thing" on it inside the sleeve, because that would tell me which model stem you need.
