Can I put everything in one trench in slab?
Discussion in 'Remodel Forum & Blog' started by guy48065, Sep 27, 2013.
  1. guy48065
    guy48065 Member
    Sep 26, 2013
    SE and north MI
    My cottage remodel involves turning a room-on-slab into a mud room/laundry. For this to work I will need to bust out a trench across the slab over to the crawlspace where the bathroom is. Can I place hot/cold supply, washer/sink drain and electrical all in this same trench?
  2. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Yes you can, but you need to have the proper distance separation for your Local Code requirements.
    The wire will need to be rated for that use
    It should be under the slab and not in it, in my neck of the woods.
  4. guy48065
    guy48065 Member
    Sep 26, 2013
    SE and north MI
    Separation is a deal-breaker if they can't lay next to each other. Who would I ask--the building dept, electrical, or plumbing? Might I run into conflicting codes like I recently did with receptacle spacing over baseboard radiators?
  5. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Where ever you get your permit would be the place to ask.
    You can look up the proper spacing and depth on the internet.
    It depends on where you live.
    Many places are happy to get your permit money and really do not care.
    Oops, Yes I did say that.
  6. guy48065
    guy48065 Member
    Sep 26, 2013
    SE and north MI
    Permits eh?
    I've been trying for weeks just to get the zoning guy to return my call. Small community.
    Keep it simple I say.
  7. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    It looks like 12" separation is used in most areas.
    And the water line should be 12" below the frost line.
    http://www.hcnv.us/bldg_dpt/documents/utilityburial-supportrequirements5-08.pdf
    You should put warning tape in the trench also.
    Good Luck.
