Can I install conduit underneath a baeboard heater
Discussion in 'Electrical Forum discussion & Blog' started by farmfresh, Oct 5, 2009.
  1. farmfresh
    farmfresh New Member
    Oct 5, 2009
    Indiana
    I need to install 2 baseboard heaters on a brick wall in a very dry basement. I will also need to install some outlets between the baseboard heaters(the outlets will be about 4 feet to the side of the heaters). I'll run the 240v for the baseboards in conduit, but I can't seem to find any information about the legality/safety of running additional conduit for the 120 V outlets below the heaters. Seems like no problem to me, the building inspector didn't seem to have a problem with it, but also didn't seem to fully understand what I meant. Any thoughts?
  2. jar546
    jar546 In the Trades
    Feb 20, 2008
    USA
    I would only allow it if the wire was properly rated for the heat and you also provided derating calculations for the circuit.
  4. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    That's true, jar, but how much heat radiates downwards from those?
  5. Billy_Bob
    Billy_Bob In the Trades
    Apr 2, 2008
    Interesting question!
    I have no idea where you would find that data (for a baseboard heater), however I do know that when installing a wood stove, the installation instructions will require a certain R-Value (insulation) hearth/pad if installing the wood stove on a combustible material like a wood floor.
    Also there are 3 types of heat transfer... Radiation, conduction and convection. More...
    Heat...
    http://en.wikipedia.org/wiki/Heat
    Thermal radiation...
    http://en.wikipedia.org/wiki/Thermal_radiation
    Conduction (heat)...
    http://en.wikipedia.org/wiki/Heat_conduction
    Convection...
    http://en.wikipedia.org/wiki/Convection
  6. hj
    heat
    It would partly depend on whether the baseboard heats strictly by radiation, or if also uses convection currents through it. If so, then anything underneath it that could obstruct the air flow would not be permitted.
  7. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    You would seriously ask for a "derating calculation"????
    I will also ask: How much heat is actually directed down from an electric baseboard heater? Not much in my opinion.
  8. jar546
    Feb 20, 2008
    USA
    Correct, your opinion. I need facts
  9. Speedy Petey
    Jun 16, 2007
    NY State, USA
    OK then. I'll let you know when I get them. :cool:
Similar Threads: install conduit
Electrical Forum discussion & Blog PVC conduit for residential install Sep 8, 2008
Electrical Forum discussion & Blog Installing an AFCI breaker Jan 5, 2017
Electrical Forum discussion & Blog Electric baseboard installation: no junction box behind it? Nov 25, 2016
Electrical Forum discussion & Blog Transfer switch installation Sep 27, 2016
Electrical Forum discussion & Blog Installer cut off SER ground wire May 20, 2016
