can I cap off a hot water radiator?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by pronouncedeyen, Oct 1, 2009.
  1. pronouncedeyen
    pronouncedeyen Member
    Sep 10, 2009
    Baltimore, MD
    At the beginning of our bathroom remodel we removed the hot water radiator so we could redo the floor. Well everything under the floor was a disaster so we haven't put it back yet. And now it's getting cold.
    Does anyone sell a cap for the iron pipe that's the size of a standard female residential radiator fitting? If I could cap it off I could turn the heat on.
    Otherwise it's going to be a mighty cold fall/winter.
  2. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    Did your radiator have one or two pipes? If it is a two pipe system, I would think twice about capping it off. It all depends on how it is piped. If they put the radiators in a series loop, you would stop the rest of the system from getting hot water. Now if they plumbed them in a parallel type as pictured in the bottom part of the picture you might be able to get away with it. But there is a chance of causing an unbalanced load.
      File size:
      17.3 KB
      1,473
      File size:
      17.3 KB
      1,473
  4. pronouncedeyen
    Sep 10, 2009
    Baltimore, MD
    SewerRatz: It's the second kind. Two pipes to each radiator that go all the way to the big supply & return pipes in the basement. Nothing is connected in series like the first diagram.
    The problem I have is that the system is almost 100 hundred years old. I don't want to try and pull off the piece that connects to the radiator to get down to a standard iron thread to cap it off because I'm worried about things breaking apart. Do 100-year-old hot water radiators use a standard thread? Can I get a cap made out of that thread?
    If not, is there some way to cap off the pipes without removing pieces to get to a standard iron pipe thread?
  5. hj
    radiators
    Few, if any, "radiator" systems are looped. The valve and elbow threads at each end are "proprietary" and are not even interchangeable between brands, so there are NO caps that will fit them. You have to remove the valve and elbow in order to cap the pipes. Hot water components will unscrew fairly easily. Steam could be almost impossible to remove.
  6. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    I'm used to steam pipes, so this may be overkill... but...
    If it's really stubborn...
    grab a 3 or 4 foot length of 1-1/4" or 1-1/2" (whichever size best fits over the handle of your pipe wrench) steel pipe - and use it to give yourself a longer handle. The extra leverage makes a huge difference.
  7. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    You are kidding right? :confused:
  8. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    You are joking right? Or have you not seen the damage and injury that can result in doing just such a thing? Pipe wrenches are sized the way they are for a reason. Never put a cheater bar on a pipe wrench. Get a bigger wrench.
Similar Threads: water radiator
Plumbing Forum, Professional & DIY Advice Converting Steam to Water hydronic heat - how to pipe radiator? Jul 9, 2015
Plumbing Forum, Professional & DIY Advice can't get air out of hot-water radiator system Feb 17, 2015
Plumbing Forum, Professional & DIY Advice Water pressure,water hammer and hot water radiators Feb 5, 2014
Plumbing Forum, Professional & DIY Advice Advice on steam radiator air vent leaking water Jan 27, 2014
Plumbing Forum, Professional & DIY Advice 2 zone, hot water upstairs, steam radiators downstairs Oct 29, 2013
