Can a converted Delta 1500 series from '96 accept new Delta 17T unit?
jimpc
New Jersey
I have a Delta 1500 series shower unit from 1996. About 4 years ago the cartridge went and Delta sent me the 1500 to 1700 conversion kit for free, RP29405. Being that this unit is now converted can I replace it with a new 17T series Delta kit without changing the rough in valve?
Thanks
WorthFlorida
6th clinical trail chemotherapy 5/15/24
Solutions
Orlando, Florida
jimpc
New Jersey
It doesn't look the same. The conversion kit uses cartridge RP32104, the 17T uses RP47201
RP32104
Is there any kind of extra trim ring I can use if I want to replace the rough in valve from the front of the shower? I know there are ones for going from 3 handle to one handle but I already have a single handle currently there.
WorthFlorida
Solutions
Orlando, Florida
I don't think so. If you have access from the back wall of the shower, replace the entire valve body for the 17T series. I have two of them after my two bathroom remodels replacing the Moens. These Delta faucets are awesome, operate smooth and easy to control. One lever for temp and the other for water flow. Temperature balance is always right on. Once you get the temperature as you like it, all you do is shut the water off without the temperature lever needing to move. All I do is turn on the water and the temp is set and I have not had to adjust it in months. 5 or 10 years from now you'll still be able to get replacement cartridges.
jimpc
New Jersey
Thanks. The problem is the frame of the closet behind the one shower is directly behind the valve. The other bathroom there is a cabinet behind the valve. We aren't remodeling. Maybe I'll just get the front cover plate they use to convert the multi handle to single handle.
