Can 2 Power Vent water heaers share same vent?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by edbreyer, Feb 11, 2005.
  1. edbreyer
    edbreyer New Member
    Oct 19, 2004
    I need to install a second power vent water heater (new master bath/whirlpool) and had assumed I'd need to have a second PVC vent line run out the side of the house. However, a contractor friend thought it was possible to share the existing vent line.
    Seems to me that without some sort of damper - the exhaust from one water heater might back feed to the other water heater and enter the utility room.
    Also - will the existing 1/2" gas line be sufficient for both heaters? They will rarely run simultaneously as I'm installing them in series and the first in the series (which will feed the second heater) will have a remote control which will only allow it to turn on when we're planning to need the extra capacity (e.g. whirlpool use or overnight guests).
  2. jadnashua
    You should be able to find the installation instructions on teh web, or look at the ones that came with the tanks. Note I'm not a pro, but I've been looking at power vented appliances for awhile trying to decide what brand and the best way to install, and all of them I've looked at specifically state you CANNOT share the vents. AND, there are some pretty specific requirments about how far apart they can be, and their placement relative to other openings, overhangs, etc. Check yours, but I'd be surprised if they can.
  4. edbreyer
    edbreyer New Member
    Oct 19, 2004
    Thanks for the response
    Thanks for the response - I'll check the installation instructions as suggested but agree that it's very unlikely they can share the same exhaust vent.
Similar Threads: Power Vent
Plumbing Forum, Professional & DIY Advice Frozen pipe prevention for Mobile home after power outage... insolvable problem? Feb 7, 2014
Plumbing Forum, Professional & DIY Advice Gas Hot Water Heater leaking (Power Venting) Jan 4, 2011
Plumbing Forum, Professional & DIY Advice g.e. power vent water tank fault codes Nov 26, 2008
Plumbing Forum, Professional & DIY Advice Replace dinosaur electric with electric, power or direct vent? Apr 30, 2008
Plumbing Forum, Professional & DIY Advice Premier Power Vent 90% Efficient Gas Water Heater Apr 10, 2008
