By pass plug {suntec pump}
Discussion in 'HVAC Heating & Cooling' started by w kern, Jun 16, 2013.
  1. w kern
    w kern New Member
    Jun 16, 2013
    central pa
    I want to add the two pipe system to my oil burner, bought the by pass plug,1/16 for a A pump,should it have a 1/16 hole ?
  2. gennady
    gennady New Member
    May 24, 2012
    Installing high efficiency heating and cogeneratio
    Brooklyn, New York, United States
    to convert to 2 pipe system, remove return port plug and install by pass plug, then connect return line, shut off valve on return line must not be installed.
Similar Threads: pass plug
HVAC Heating & Cooling Is a bypass humidifier a bad idea for a condensing gas furnace? Dec 28, 2014
HVAC Heating & Cooling Humidifier Bypass Duct Placement Help Needed Jan 10, 2014
HVAC Heating & Cooling Drain for Bypass Humidifier Feb 15, 2010
HVAC Heating & Cooling Humidifier Bypass Jan 9, 2010
HVAC Heating & Cooling Boiler bypass using mixing valve?? Feb 18, 2009
