Dis360
I have well water, the well is ~250ft deep and provides ~6GPM. I shock the well about every 6 months. I purchase my home about a year ago and noticed immediately that the water needed to be filtered, as there was no filtration whatsoever and there was staining in the shower and toilets, light brown staining that I assumed was iron at the time. I could also fill up a water bottle and while the water looked very clean and clear initially but if sits for 24 hours+, it develops a hazy tan color and would have clumps of brown sludge on the bottom. I also noticed what I identified as iron bacteria in the back of the toilets.
That's the background, so I built a whole house filter setup, with three 10" filters and a UV filter. As a starter I used filters obtained at home depot, generic carbon, string and poly and have used a combo of them over the past 9 months, that seems to work alright, I was not expecting a lot out of those. I am planning to get more suitable filters, like a dedicated sediment filter (20 micron) and smaller and smaller in the other two pods. Although the water is cleaner, I still have the hazy water with tan clumps in the bottom. I also test my water every few months and there is nothing out of range of normal, no iron.
I decided to install a spin down filter with a 50 micron stainless steel screen yesterday to help prolong the filter life and capture larger particles. My next step was to get three proper subsequent filters but I was stopped in my tracks once I saw how fast the spin down filter became clogged. It clogs in minutes with what I assume is clay, when I say it clogs, the entire screen is covered and there is a significant pressure drop at the taps, the screen is covered in clay, although there are black and red larger particles but they sink. Now I'm rethinking everything and no longer think this staining in the toilets is iron but rather this clay and don't know where to go from here, if I get a higher micron screen this clay will just pass through and continue to clog the filters down stream and apparently some clay is still making its way through hence the staining.
Additional thoughts, my refrigerator water filter produces 100% clean and clear water, so even though it's not a whole house filter, all sediments can be completely filtered out, probably a membrane in there or something. Another interesting topic, I once sanitized my well, flushed all chlorine out, water ran for 4-5 hours, about and hour after this I filled up a small pool with about 450 gallons of water and to my surprise it was crystal clear and stayed that way. I filled it up again a couple of months later and the water appeared hazy, tan/brown and cant see through it, its interesting how clear it was after flushing the well.
I need advice on 2 things:
1. How do I get rid of this clay and is that what's in the bottom of a water samples and causing the haziness?
2. What spin down filter size do I need and what should I use in the three 10" pods?
(1.) 20 micron sediment / (2.) 10 micron carbon block / (3.) 1 micron pleated
The pictures are of, three water bottles, water from tap few days old (left), tap 10 hours old (middle), sealed bottled water (right). Sediment in left bottle. Spin down filter after a few minutes. Water bucket I toss used filters in, can see sediment in bottom
Video of spin down: https://drive.google.com/file/d/1YENLQ17KVja_1w0cDtesZzZ_la1mMDnU/view?usp=sharing
Thank you for your time and help.
Daniel
Daniel
