bubbles in water
Discussion in 'Water Softener Forum, Questions and Answers' started by mike891, Mar 8, 2009.
  1. mike891
    mike891 New Member
    Mar 7, 2009
    have water softener salt level fine regeneration fine recently turned off water upstairs to remodel bathroom lately water from tap looks cloudy turns out it's bubbles they all rise to top of glass and water then looks clear never had this problem before have a well pressure is fine anybody have any ideas what could be the cause of extreme aeration thank you
  2. mike891
    mike891 New Member
    Mar 7, 2009
    bubbles
    thanks, will check softener because bubbles have been going on for about 2 wks
  4. Gary Slusser
    Retired
    you can check to see if it is the aerator adding the water by removing the aerator and drawing water into a glass and if it doesn't have the air then it is the aerator causing the air like they are supposed to it could be lose brine line connections on the softener or the air check valve isn't sealing because it has something blocking it from sealing or it could be the valve you shut off sucking air around the stem packing
  5. mike891
    mike891 New Member
    Mar 7, 2009
    gary, thank you it was the valve i shut off sucking air
  6. Gary Slusser
    Retired
    You're welcome Mike, thanks for the feedback.
    Sammy, if you read this, maybe your air in the water is a valve stem leak on a shutoff valve.
  7. sammyhydro11
    sammyhydro11 Previous member
    Dec 20, 2006
    Well Drilling-Test Borings-Water Treatment-Well an
    Massachusetts
    Gary, i know where my customers well problems come from but thanks for the suggestion.
    sammy
    www.tylerwellandpump.com
Similar Threads: bubbles water
Water Softener Forum, Questions and Answers Lots of bubbles in water (cloudy) that dissipate...help! Jan 13, 2014
Water Softener Forum, Questions and Answers Advice for replacing a water softener for iron removal Yesterday at 12:24 PM
Water Softener Forum, Questions and Answers I need a professional’s guidance in replacing my water softener. Feb 13, 2017
Water Softener Forum, Questions and Answers Opinions on treating well water Feb 12, 2017
Water Softener Forum, Questions and Answers Resin in Water Feb 12, 2017
