Yellow water again a week after new water softener installed
J1624
Northville, mi
We just had a new aqua sure water softener installed about a week ago. We went about 5 weeks without a softener in between the old one giving out and installation of new one. In that 5 weeks the water stained everything. The cold water would come out clear, but then turn yellow after sitting. Bath tub water would also come out yellows but quickly turn dark.
One the new softener/filtration system got installed everything seemed good within a day or so. Typical black water coming out once water came back on and yellow hot water coming out that needed to be flushed, but then everything seemed fine. No more yellow toilet water or clear water turning yellow.
Yesterday we notice some black flecks coming out of bathroom tub faucet. Then I notice the toilet water was a fight light yellow. Noticed the pets water turning yellow after it sat in the bowl. Today the bubble bath was a nice yellowish orange.
Why is this happening? We thought replacing the water softener would fix these issues? Why was it fine looking for a week and now it’s tinted again with sediment?
Bannerman
Ontario, Canada
Supply further info including the model and capacity of your new softener, water hardness, number of residents and whether your water source is municipal or a private well. If private well, post a copy of your most recent lab test report so we will know if there is iron and/or manganese present and if so, how much of each along with other water conditions.
You mention a filtration system but didn't specify the type, size or purpose. A water softener is not a filter.
A water softener is not a sediment filter.
Master Plumber Mark
www.weilhammerplumbing.com
You must be on a well and have high iron levels in your water ....
You either need an iron filter before the water softener because a common water softener will take out maybe 3 parts per million of iron.....
and you could have biological iron in your water too.....
Whomever installed the new system needs to come back make this right
or did you do this yourself??
J1624
Northville, mi
That’s a lot of information I unfortunately do not have all of the info to. This is the first house we’ve lived in on a private well. It’s an aqua sure water softener and filtration system. I think it is a harmony- but I’m unsure of the exact descriptions.
J1624
Northville, mi
Someone else installed it, and I’m just waiting to hear back from him.
Yes- we definitely have high iron in our water. I am going to see if I can get a specific or maybe a better iron filter. There is a filter in the new system- I just don’t know the specifications or if it needs to be bette than what it is.
Forgive my ignorance- what is biological iron too?
We never had issues like this consistently until the old softener was starting to go. It was old. I know absolutely nothing about why this happens.
J1624
Northville, mi
Do you have any recommendations on getting lab tests done of my water?
Master Plumber Mark
J1624
Northville, mi
if you are on a well you probably need an air injection type of iron filter before the water softener
not just some wimpy small thing hanging on the wall .....
Thank you for the recommendation.
J1624
Northville, mi
And yes- we are on a well.
