Brown stuff in my water.
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by oilyfishhead, Apr 15, 2008.
  1. oilyfishhead
    oilyfishhead New Member
    Apr 15, 2008
    Computer Wiz
    Louisburg, NC
    Oh no, another thread about brown stuff. :)
    Hi y'all. I just found this forum and thought maybe I could get some advice.
    My well is 215 feet deep. Water comes up to 25 feet. The pump is at 70 feet. My water gets this cloudy brown stuff in it. It is fine enough that a paper cartridge will only get about 75% of it. The brown stuff will settle out if it sits for for a while. (i.e. in the toilet.) If I run the water, before the filter, for an hour it clears up. If I shut off the water, it will be brown again the next day. I have no fancy equipment in the system. Pump is in the hole. Water goes to the accumulator then through a paper cartridge filter(useless) then to the house. The cartridge filter will be mostly clogged in about 2 weeks.
    Any suggestions?
    thanks
  2. Gary Slusser
    Retired
    Why is the pump at 70' in a 215' deep well!
    The brown may be iron. Get a water test for hardness, iron, pH and Coliform bacteria at least and post the results.
  4. oilyfishhead
    Apr 15, 2008
    Computer Wiz
    Louisburg, NC
    I'll get it tested.
    Why would the depth of the pump be a concern? That's the way it was when I bought it. It flows plenty. I can fill my swimming pool in a couple of days with a 3/4" hose.
  5. Gary Slusser
    Retired
    If you have iron in the water, and it is easily oxidized, it will oxidize in the water at the top of the well long before deeper water because of the top of the water column being in touch with air in the well. And then the draw down of the well exposes the surface of the well and the water on it will oxidize more iron which can make the water discolored.
    Also, the water below/under the inlet of the pump is all unusable, stagnant water just laying there in many cases with a rock bore type well. And a fully cased and screened type well in sand and gravel, usually has the pump set at the area of screen with the most gpm flow.
Similar Threads: Brown stuff
Pumps and Tanks Well Forum & Blog. Water is life. Dug Well, Brown Water Nov 17, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well Water dirty brown after home inspector's flow test Jun 28, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Brown/ Orange Water Jan 11, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Brown water....worried Jun 28, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Replaced bladder tank and now have very brown water Oct 3, 2012
