lhartl
Good day. First let me tell you that I am at our cabin - 30 minutes from the nearest small town hardware store (Barriere, BC) and 90 minutes from a town with Home Depot or similar (Kamloops, BC). I have called three plumbers - no answer back from anyone yet, so I humbly ask for your online help. My skill level is moderate at best.
The hot water faucet in the bathtub will not shut off. I removed the faucet and valve and out came a chrome tubular thingy (1.5 inches long, 3/8"diameter) with a small rim on the top - it is obvious that it has broken off. I am assuming it is the 'seat'of the valve. What is left when I feel inside the hole in the wall is flush so I am not sure if it was threaded in there or not AND there is no lip to unscrew it and the inside wall of it is smooth - anyway I cannot get it out.
My question - do I need to replace the whole tap set? If so, which wall should be taken out? I could take out the gyproc in the utility room (behind the bathroom) or.... I could peel back the wall liner and hope to glue it back on again. Neither options sounds great - ugh.
I do not have a soldering apparatus - I sure hope there is a non-solder method available to a newbee.
I am desperate for your opinion - thanks,
Linda
Linda
