Bradford WhiteAnode Replacement
Discussion in 'Water Heater Forum, Tanks' started by vaman77, Jul 21, 2011.
  1. vaman77
    vaman77 Member
    Jan 1, 2011
    NJ
    I have a Bradford white water heater that is about 18 years old. I have occasionally drained and am going to again. I thought I'd replace the anode this time. It has never been replaced. Is it worth it to do it now and am I asking for more trouble than it's worth?
    thanks
  2. jadnashua
    At 18-years, you are beyond the norm for replacement of the whole thing. But, some do last a lot longer. Depends somewhat on luck of the draw and the quality of the water. If you have an impact wrench, you should be able to get the old rod out, a breaker bar may not do it. Then, depending on the available height above it, you may need to buy a segmented replacement rod rather than a solid one. It's a tossup now, as the old rod is probably used up, and any impact may open up additional opportunities for it to then start leaking. Depends on how lucky you feel.
    Draining helps by removing any debris and maintaining the heating and volume of hot water you can get from the tank, but probably doesn't do much to extend the useful life from leaking.
  4. ballvalve
    Dec 28, 2009
    northfork, california
  5. vaman77
    vaman77 Member
    Jan 1, 2011
    NJ
    Anode Where is it?
    Am looking at this heater and can't figure out where the anode is.Pictures I've seen show it accessible from the top which makes sense. The unit is one of those vented models with a fan on top.So do I have to take that off along with the accompanying wiring? It looks like this thing was made not to replace the anode:(
  6. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    leave it alone
    anode rod is incorporated into the hot water line nipple going intot he power vented heater...
    I suggest you leave it alone,,, if you have gotten 18 years out of a power vent heater its best to leave
    sleeping dogs lie,
  7. hj
    Your heater is old enough that it should be located on top near the back, but after 18 years, your heater is well past the time when an anode rod would be needed.
  8. vaman77
    vaman77 Member
    Jan 1, 2011
    NJ
    Thanks will do.
Similar Threads: Bradford WhiteAnode
Water Heater Forum, Tanks Bradford White - Is a Gas Leak from Control Valve Normal? Sep 9, 2016
Water Heater Forum, Tanks Bradford White Combi Core 1 vs Combi Core 2 Jun 1, 2016
Water Heater Forum, Tanks Bradford White pilot issues Apr 1, 2016
Water Heater Forum, Tanks Bradford White low nox repeated flame rollout. Jun 28, 2015
Water Heater Forum, Tanks Water heater control valve? Bradford White MI40T6FBN Jun 26, 2015
