Right now it's $1.05 per liter for oil and I pay $.63 per liter for propane. I have last winters oil numbers so I'll have to compare with this winters propane. Of course a different boiler too. I guess if it's more expensive I'll have to find an experienced hydronic installer to help find a solution to find better efficiencies. Thought was going with a propane boiler would save me some money.
At those prices the heating cost is you'd be better off spending the money on cold climate ductless mini-split heat pumps than a condensing propane boiler.
The 1-ton Fujitsu 12RLS3H delivers over 15,000 BTU/hr @ -20C, and about 12,000BTU/hr @ -25C. They make a 1.5 ton and a 0.75 ton versions too. A pair of the 1 tonners would deliver about the same amount of heat as your boiler at it's current burner settings. In my neighborhood the 1-tonners cost about USD$3800-$4000 each, all-in, fully installed & commissioned with warranty. A DIY installation can cost less than USD$3K, including the cost of a service call from a refrigeration tech to install the refrigerant and check the performance.
At -20C their coefficient of performance (COP) is about 2.0, and about twice that at -10C. A COP of 2 means for every kwh of power in you get 2 x 3412BTU/kwh= 6824 BTU/kwh.
A liter of propane has about 24,170 BTU source energy, burned at 85% efficiency delivers about 20,545 BTU of heat into the house.
So at -20C it takes 20,545/6824= 3 kwh to deliver the same amount of heat into the house as a liter of propane. Does your electricity cost more than $0.63/3= 21 cents/kwh?
In most of Ontario it's less than 15 cents.
At 15 cents/kwh during the shoulder seasons heating with mini-splits would cost less than half what it costs with $0.63/liter propane.
Mitsubishi's FHxxNA minisplits are roughly comparable in heating capacity as the Fujitsu xxRLS3H. Somewhere between -28C to -32C the Mitsubishi units can turn them selves off to self protect when their outdoor temperature sensor is out of range, but will automatically re-start at -25C. If you have the propane burner as backup that's not a disaster, but if you didn't some other backup would be a serious consideration in a climate as cool as yours.
Fujitsu units don't have that issue, and will keep running at -30C or cooler and still putting out heat, though the heating capacity isn't specified at temperatures below -26C. I know of one guy in Quebec heating his house with four earlier-generation 3/4 ton Fujitsu 9RLS2H who is satisfied with their capacity & performance at -30C. The newer generation versions have better capacity and efficiency than his.
