BruceY
- Messages
- 14
- Reaction score
- 0
- Points
- 0
I have two sinks feeding into one drain. The first sink is a typical kitchen sink. that drain goes thru the floor, into my basement and ties into the main drain exiting the house. The second sink is a small wet bar sink located in the next room. THAT sink has a lead drain pipe that ties into cast iron. The kitchen sink is copper and ties into the same cast. Imagine the letter Y. It's bacicaly like that and the easiest way for me, to describe to you, how it's set up. It's been this way for over 30 years with NO problems. There is a vent stack in place for as long as we've been here.
Starting last year the bar sink blurps when soapy water is discharged down the KITCHEN sink. Some one told me the vent pipe was clogged. I got up on my roof, seen it was clogged with a garden hose and snaked it clean, tested with a hose and it seemed fine. For a short while if at all.
I'm not sure if the bar sink is sucking air or blowing bubbles. I've used drain openers, snakes, and pulled "gunk" out of a cleanout in the basement.
I need to get this resolved for I have my home on the market. I can send a more detailed diagram if needed.
HELP HELP AT WITS END
