Blower not turning off
Discussion in 'HVAC Heating & Cooling' started by jerome8283, Aug 13, 2011.
  1. jerome8283
    jerome8283 New Member
    Oct 4, 2006
    New York
    Got up this morning and my central air blower was running but the compressor was off. It seems to be switch related because the compressor did come back on after the temperature rose. Usually when I turn off the air from the thermostat the compressor and blow turn off. Now the compressor turns off only. What could be the problem?
  2. jerome8283
    Oct 4, 2006
    New York
    Fan setting was not set to auto! Problem solved! :)
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    An easy fix and one you'd kick yourself for if calling out a tech.
    My wife called out a tech for an intermittent furnace problem where it would run for less than a minute and shutoff. The tech tore the furnace apart before realizing the problem. Turns out the wife tossed a blanket on top of the garbage cans that where right below the fresh air intake for the furnace. The wind was blowing up a flap of blanket that would sometimes block the intake. DOH!
Similar Threads: Blower turning
HVAC Heating & Cooling Blower won't come on on "auto" but does with "on" Oct 29, 2016
HVAC Heating & Cooling Forced Air Blower Oct 12, 2016
HVAC Heating & Cooling Furnace blower bearing isolaters.... Sep 25, 2016
HVAC Heating & Cooling Blower motor not starting Aug 30, 2016
HVAC Heating & Cooling Random Main Blower Cycling Apr 28, 2016
