Black Spots on tub
Discussion in 'Shower & Bathtub Forum & Blog' started by BMWGreenRT, Jun 26, 2005.
  1. BMWGreenRT
    BMWGreenRT New Member
    Jun 26, 2005
    Ashville, North Carolina
    Some background info first.
    I am in a brand new home, my water heater is a Bradford White 50 gallon.
    It has a powervent installed. The 2" into 3" PVC vent pipe goes up about 2 feet and then horizontally for about 15 feet where it vents out of the basement wall.
    I have a 72" by 48" fiberglass tub in white.
    I have the unit set above the normal heat to a hotter setting, but not the highest available.
    We are on City water not a well.
    I have noticed little black specks on the bathtub recently. There is no shower in the tub. They were not there for the first three months of use. When rubbed they spread like ladies mascara would spread. It takes some rubbing and cleaning to get rid of them.
    I thought at first maybe it was some kind of mold, but since it was only inside the tub, I decided to clean it with a 50/50 bleach water mix.
    I let the tub sit for 3 days and nothing else appeared.
    But once I filled the tub again with hot water, the little specks appeared again.
    They are not in the sinks or toilets.
    The toilets "do" show a very light pink colored ring at water level if not flushed for a couple of days, which cleans off very easily.
    Does anyone have any idea what this is called, what causes this and how I can get rid of it.
    All help would be appreciated.
    If you need more info please ley me know.
    Thank-you,
    Jim
Similar Threads: Black Spots
Shower & Bathtub Forum & Blog black spots in bathtub Jan 8, 2007
Shower & Bathtub Forum & Blog Broken tailpiece stuck in black ABS fitting Mar 11, 2017
Shower & Bathtub Forum & Blog Back to the black particles in the tub faucet and the toilet in the main bath.... Nov 23, 2016
Shower & Bathtub Forum & Blog Black soot in tub Jun 27, 2014
Shower & Bathtub Forum & Blog Black particles in bath hot water only Nov 28, 2012
