Black pipe fittings
Edomina
In routing 1/2" black pipe for gas, is it ok to have two fittings together and no nipple between them. For example, can you have a street 90 go into a valve, or a reducer go into valve?
Don't know about IPC but UPC lists approved fittings that may be concealed "fittings such as tees elbows and right left nipples and couplings" other codes list fittings that are cast as being prohibited.
My experience and observation has been bell reducers are ok to use anywhere, bushings ok in un concealed spaces. gas company routinely uses them (bushings) at meter locations.
Been a bit of gray area to me don't know if a street 90 is "cast" or not but had some discussion in past on using for gas I used them many times but uncertain of legality, we used them (street 90s) occasionally on log lighter connections. I never use bushings buried in wall just because of controversy
Tuttles Revenge
I don't know about IPC, but there is no reference to bushings or street fittings being prohibited in the UPC. I think Sylvan tho made a good point that with especially street 90's, their inside diameter is diminished. In Seattle I can not use Bushings or Street fittings in my work inside homes.. but the utility routinely uses them on their meters.
